单人参数(116KG以下哟) 40万RMB 图见http://www.doyouhike.net/forum/194098,0,0,1.html
Length: Frame 16 ft., Overall 20 ft. Width: 72 in., Height: 84 in.
Rotor Diameter: Main 19.5 ft., Tail 40 in.
Empty Weight XE: 298 lb
Empty Weight XEL: 312 lb
Gross Weight: 610 lbs
Useful (Pilot) Load: 240 lbs.
Fuel Capacity XE: 12 US gallons
Fuel Capacity XEL: 5 US gallons (as required by FAA Part 103, Ultralight Regulations)
Engine: Compact Radial Engines MZ202, 2 cylinder, 2 stroke, rated 64 HP (45kW)
Electrical System: 12 volt DC battery, starter, 180 watt alternator
Rotor Speeds: Main 520 rpm, Tail 2500 rpm
Fuel Flow at Cruise: Approximately 4 U.S. Gallons per hour
Flight Duration XE: Approx. 140 minutes depending on conditions, loading, speed, etc.
Flight Duration XEL: Approx. 60 minutes depending on conditions, loading, speed, etc.
Performance: Hover in ground effect: 8,000 ft. (estimated)
Hover out of ground effect: 6,500 ft. (estimated)
Max Speed: 75 MPH
双人参数 80万RMB
Gross Weight 1500 lbs. (680 kg)
Empty Weight 975 lbs. (442 kg)
Equipped Useful Load 525 lbs. (238 kg)
Pilot and Passenger Load 425 lbs. (193 kg)
Fuel Capacity 17 U.S. Gallons (64 liters)
PERFORMANCE
Rate of Climb 1000 fpm
Hover In Ground Effect 7000 ft.
Hover Out Of Ground Effect 5000 ft.
Service Ceiling 10,000 ft.
Range, Max. Fuel Cruise 80 mi./2 hrs.
Normal Cruise 95 mph (83 knots)
Max. IAS, Sea Level/Standard Day 115 mph (100 knots)
BASIC DIMENSIONS
Main Rotor Diameter 25 ft. (7.6 meters)
Tail Rotor Diameter 50-1/4 in. (1.2 meters)
Length, Nose to Tail 22 ft. (6.7 meters)
Overall Length 29-1/2 ft. (9 meters)
Cabin Width 44 in. (1.1 meters)
Skid Width 65 in. (1.6 meters)
Height 96 in. (2.4 meters) |
