建议使用HK4025至于KV值就要看您用多大的电池了
HK-4025 Series Motors
The HK-4025 series of motors is designed for helicopters with 600 to 650mm blades such as the Logo 600 and Trex 600. There are 4 motors available in this series, for a variety of battery sizes and gearing options. Here is a list of the basic specs for these motors.
HK-4025-630, Kv = 630, Pmax = 2520W, Imax = 60 Amps
HK-4025-740, Kv = 740, Pmax = 24500W, Imax = 70 Amps
HK-4025-890, Kv = 890, Pmax = 23800W, Imax = 85 Amps
HK-4025-1100, Kv = 1100, Pmax = 2200W, Imax = 100 Amps
The 1100Kv motor is designed for operation on 6 Li-Po cells, the 890Kv motor is designed for use on 8 Li-Po cells, the 740Kv motor is designed for use on 10 Li-Po cells, and the 630 Kv motor is for use with 12 Li-Po cells.
HK-4035 Series Motors
The HK-4035 series of motors is designed for helicopters with 690 to 720mm blades such as the Trex 700E Or for people that want a lot of power in a 600 class machine. There are 3 motors available in this series, for a variety of battery sizes and gearing options. Here is a list of the basic specs for these motors.
HK-4035-500, Kv = 500, Pmax = 2520W, Imax = 60 Amps
HK-4035-560, Kv = 560, Pmax = 24500W, Imax = 70 Amps
HK-4035-630, Kv = 630, Pmax = 23800W, Imax = 85 Amps
The 630Kv motor is designed for operation on 8-10 Li-Po cells, the 560Kv motor is designed for use on 10-12 Li-Po cells, and the 500 Kv motor is for use with 12-14 Li-Po cells, depending on the gearing used and the desired head speed. |
