查看: 1790|回复: 4
动力伞飞行手册(FAA)以及评价
发表于 2008-2-14 09:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
动力伞飞行手册(FAA)以及评价FAA出版的“动力伞飞行手册”,下载链接如下:
http://www.faa.gov/library/manuals/aircraft/media/FAA-H-8083-29.pdf
 楼主| 发表于 2008-2-14 09:50 | 只看该作者
读者对该书的评价
Just finished reading this new handbook.
Absolutely superb. Easy to read, brilliantly illustrated with clear informative diagrams and pictures.
Not as detailed as the PPC Bible but better overall as it contains very practical info and is
   exactly what the beginner (and experienced) powered parachutist requires.
This handbook will set the standard for all handbooks on PPC.
My advice: Download it in PDF format and set aside 4 hours to read it. Believe me, you wont be able to put it down once you start.
Congratulations to the authors. You have done a first class job.
 楼主| 发表于 2008-2-14 09:52 | 只看该作者
其他读者的评价如下:
http://www.ppcflyingforums.org/forums/showthread.php?t=3203
发表于 2008-2-14 10:13 | 只看该作者
评价
 楼主| 发表于 2008-2-14 18:21 | 只看该作者
上述内容对动力伞的初学者来讲,是比较好的学习材料。
