查看: 4516|回复: 30
取代10x的新版遙控器,JR12X/2.4ghz 9303
发表于 2007-4-21 09:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
这个不知大陆什么时候会有货..12X的长相和9X如出一辙..想了解更多请:www.jrradios.com
JR 2.4GHz Programmable Systems
JR® is pleased to announce two new pro-class, programmable aircraft systems—the
9-channel X9303 2.4 which is coming this summer, followed by the 12-channel 12X this fall. Both will feature all the software sophistication JR is known for, PLUS the no-pins, no-crystals, no-glitches convenience and security of proven DSM2™ 2.4GHz technology by Spektrum™.
DSM2: 2.4GHz RC Technology with a Flawless Record
Unlike ordinary spread spectrum ICs, the unique chip that’s the basis for Spektrum’s 2.4GHz technology was developed specifically for RC by an avid aircraft modeler who wanted to create a robust, ultra-reliable RF link that would be immune to glitches and interference. This chip combined with Spektrum’s patent-pending DSM/DSM2 protocols, and the built-in redundancy of its DuaLink™ technology, have been the biggest revolution in RC flying since the advent of digital proportional control. It’s proven 2.4GHz technology that JR is proud to adopt––technology that’s been used with unprecedented success by thousands of RC car and airplane modelers since 2005.
Complete Integration Means Faster Response and Added Precision
Because DSM2™ technology has essentially been “built-in” to these new JR systems there is no processing time lag as there would be with a module based system. In fact, you will experience response times that are faster than any PCM system in existence. You will also enjoy two other exclusive DSM2 features you will wonder how you ever lived without—ModelMatch™ and ServoSync™.
ModelMatch puts an end to “wrong model” mishaps by preventing the receiver from responding until you select the memory settings matched to the model you’re going to fly. ServoSync automatically resequences transmitted data bits so that mixed servos receive their pulses in direct sequence. No longer will you have to endure split second differences in CCPM or dual elevator servo movement. All servos will move as if on the same channel so you can fly with absolute precision.
Complete Compatibility with Spektrum Brand DSM Receivers
If you already own a Spektrum brand radio system you will be pleased to know that both of these new systems will work with any DSM receivers you already have, including the AR6000, AR6100, AR7000 and AR9000. So, when the time comes to move up to more channels you’ll be set.
X9303 2.4 9-Channel DSM2 Aircraft System—Available Summer ‘07
As the foundation for an advanced, full-range, spread spectrum radio, it’s hard to imagine a more ideal candidate than JR’s XP9303.
A breakthrough in versatility and flexibility when it was introduced, the 9-channel, 30-model memory, 3-model type 9303 is an enormously popular radio upgrade for flyers whose skills have outgrown sport-class equipment. With software shaped by the input of top airplane, sailplane and heli pilots, plus its exclusive rolling ease and speed of programming, the 9303 remains the standard by which all 9-channel radios are judged.
And now, with the added convenience and security of Spektrum DSM2 2.4GHz technology, the newly-designated X9303 2.4 is destined to be a breakthrough once more.
Spektrum engineers have even incorporated technology that permits owners of conventional XP9303 radios to transfer all of their model programming data from their transmitters directly to their new X9303 2.4 transmitters.
JRP2910 X9303 2.4 Airplane/Sailplane DSM2 System Street Price: $729.99
JRP2920 X9303 2.4 Heli DSM2 System Street Price: $729.99
12X 12-Channel DSM2 Aircraft System—Available Fall ‘07
Big-scale and jet modelers as well as anyone else flying complex applications will love the new JR 12X.
The pro-class 12X will combine airplane and heli programming in a single transmitter. All programming functions will be easily adjusted using JR’s exceptionally intuitive Rolling Selector input system. Plus, its big, high-resolution dot matrix display will allow you to see the adjustments you make with absolute clarity.
Item #: TBA
Price: TBA
The Bottom Line
JR programmable systems have always been known for superior quality, unmatched Horizon Hobby product support and intuitive programming that offers all the features you could ever need. With the X9303 2.4 and 12X, you will get all of this plus the addition of Spektrum 2.4GHz convenience and security making them the most advanced radio control systems ever. Simply put, these are the systems the world’s been waiting for.
JR is distributed exclusively by:
Horizon Hobby, Inc.
4105 Fieldstone Rd.
Champaign, IL 61822
(217) 352-1913
www.jrradios.com
 楼主| 发表于 2007-4-21 09:50 | 只看该作者
主菜单.
同样的7点曲线.
发表于 2007-4-21 11:03 | 只看该作者
:em20: ,不会吧,怎么看着象欧版的9X2
发表于 2007-4-21 20:02 | 只看该作者
:em09: :em09: :em09:
JR没有创新!!!
发表于 2007-4-21 21:41 | 只看该作者
:em23:
发表于 2007-4-21 21:44 | 只看该作者
:em05:
发表于 2007-4-22 23:11 | 只看该作者
JR看来关门是不可争论的事实了.悲哀
发表于 2007-4-23 13:01 | 只看该作者
:em20: 不怎么好看
发表于 2007-8-2 13:51 | 只看该作者
:em15: :em15:
发表于 2007-8-2 14:00 | 只看该作者
英文
发表于 2007-8-2 14:01 | 只看该作者
:em26:
发表于 2007-8-2 14:22 | 只看该作者
:em15: :em15:
发表于 2007-8-2 14:24 | 只看该作者
看起来不错哟!就是价格不知道怎么样??
发表于 2007-8-2 15:35 | 只看该作者
操作系统还是XP9303...:em15: :em24:
发表于 2007-8-8 13:52 | 只看该作者
12x越看越喜欢!
要专业还是JR
FU的太花捎了.
发表于 2007-8-8 13:57 | 只看该作者
原帖由 正负螺距 于 2007-4-22 23:11 发表
JR看来关门是不可争论的事实了.悲哀
只能说没用过JR.
不知者不怪吗!
发表于 2007-8-13 00:37 | 只看该作者
看起来不错哟!就是价格不知道怎么样:em15: 越看越喜欢:em07:
发表于 2007-8-13 08:09 | 只看该作者
:em26:
发表于 2007-8-13 23:57 | 只看该作者
JR其实不错.
发表于 2007-8-15 07:18 | 只看该作者
喜欢
