查看: 3786|回复: 3
动力辅助三角翼——棒极!
发表于 2008-7-27 12:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
发表于 2008-7-28 09:08 | 只看该作者
好东西,造价也低。
澳大利亚的airborn的悬挂三角翼fun 190 价格是4354澳元,折合人民币2万6千。外加一个14.2马力的瑞典raket 120 (7800RMB)+自己制造一个发动机支架,就ok。
GLIDER FUN 190 COLOUR STOCK 108602 4,354.00 $ $ 4,789.40
发表于 2008-8-2 18:48 | 只看该作者
介绍Powered hang glider的网站:
http://en.wikipedia.org/wiki/Powered_Hang_Glider
介绍内容:
A foot-launched powered hang glider (FLPHG), also called powered harness, nanolight or hangmotor, is a powered hang glider harness with a motor and propeller in pusher configuration. An ordinary hang glider is used for its wing and control frame, and the pilot can foot-launch from a hill or from flat ground, needing an area of about the size of a football field to get airborne, or much less area if there is an oncoming breeze and an absence of obstacles. Although the main appeal of FLPHGs is to the already experienced hang glider pilot, interest in these machines is growing rapidly, particularly in areas where there are no hills for foot-launching.
The pilot can cruise around in good weather at speeds of 40 to 72 km/h (25 to 45 mi/h), but powered harnesses have limited power and thrust, so are best used as a self-launch device in order to achieve enough altitude to find a warm-rising air thermal for soaring.
帖子425 精华3 积分1461 资源分251 分 From中国深圳 阅读权限40 在线时间587 小时 最后登录2008-8-2 查看详细资料
编辑 引用 报告 回复 TOP
发表于 2008-8-31 14:36 | 只看该作者
不错
