查看: 2558|回复: 15
SPEKTRUM DX20 發表新控
发表于 2016-1-29 08:32 | 只看该作者 |只看大图 回帖奖励 |正序浏览 |阅读模式
KEY FEATURES
  • Carbon fiber front case
  • Machined-aluminum, quad-bearing gimbals
  • Interchangeable leather side grips
  • 20 fully-proportional channels
  • 250-model memory
  • Voice alerts
  • Wireless trainer link
  • Independent multi-engine control for airplanes
  • ProTrim in-flight adjustment of rates, expo, mixes and differential
  • 11ms frame rates with capable receivers
  • Built-in telemetry with vibe or voice alerts
  • Airplane, helicopter, sailplane and multirotor programming
  • 11 airplane wing types
  • 6 airplane tail types
  • 2 canard options (1 rudder or 2 rudder) with elevon wing types
  • Active gyro trim
  • 5 airplane and heli flight modes
  • 7 swashplate types
  • Swashplate timing
  • 7-point airplane and heli throttle curve
  • 7-point heli pitch curve
  • 7-point heli tail curve
  • 5 sailplane wing types
  • 3 sailplane tail types
  • 10 sailplane flight modes
  • Multirotor flight mode setup, checklists and voice alerts
  • Throttle start or switch start timer
  • 16 programmable mixes
  • 0.5% mix rate increments
  • Origin mixing
  • Flap delay and elevator compensation
  • Dual rates and expo
  • Diversity antenna
  • 4000mAh LiPo transmitter battery
  • Global charging system
  • X-Plus™ technology expandability up to 20 channels
  • Large, backlit LCD screen
  • Includes AR9020 9-Channel DSMX receiver
  • Includes 3 stick end sets
  • 5 menu languages: EN, DE, FR, IT and SP
  • 2048 resolution
  • Language selectable
  • Region settings for global compliance
  • EN328 compatible
Sailplane
• 5 Wing Types: Single Aileron, Dual Aileron, Dual Aileron + Single Flap, Dual Aileron + Dual Flap, Quad Aileron + Dual Flap
• 3 Tail Types: Normal, V-Tail A, V-Tail B
• Motor Throttle Switch Assignment
• Aileron and V-tail Differential
• Camber System
• Camber Preset
• ProTrim In-Flight Adjustment of Rates, Expo, Mixes and Differential
• AS3X Gain Adjustment
• Flap Delay and Elevator Compensation
• 10 Flight Modes
• Dual Rates and Expo
• 0.5% Mix Rate Increments
• 16 Programmable Mixes
搭配一顆 AR9020   同樣採用 DSM2®/DSMX®
目前原廠網站在特價中,不過還是好貴 喔!
发表于 2016-2-9 20:24 | 只看该作者
H还能再丑点吗?
发表于 2016-1-29 17:26 | 只看该作者
还是dx8好看些,在正常风格的控里也算不错的了,就是难买到单控版的了,新的太贵,旧的不敢收
发表于 2016-1-29 11:19 | 只看该作者
总觉得有些杀马特风格
发表于 2016-1-29 11:00 | 只看该作者
感觉背面很好看,正面就一般般了
发表于 2016-1-29 10:49 | 只看该作者
用料很足好吗!就是老外的审美有些特别
发表于 2016-1-29 10:27 | 只看该作者
确实感觉丑
发表于 2016-1-29 10:24 | 只看该作者
越出越丑,模型外形
发表于 2016-1-29 10:20 | 只看该作者
发表于 2016-1-29 10:12 | 只看该作者
发表于 2016-1-29 09:31 | 只看该作者
顶级
太丑了,不如DX18
发表于 2016-1-29 09:29 | 只看该作者
那短小的鸡鸡,怎么好意思拿出去见人?
发表于 2016-1-29 09:27 | 只看该作者
感觉不怎么好看
发表于 2016-1-29 08:59 | 只看该作者
真的好丑
发表于 2016-1-29 08:45 | 只看该作者
好贵是多少钱
