这个我也不是很清楚,这是邮件原文:
Hi xxxx,
1. They are similar in ratings except for the input voltage, boost feature, physical size.
2. It has 16 AWG silicone wires
3. It is not recommended to wire to a 6s battery pack from a 12s (2x6s) pack. Due to the different brands/chemistry of the battery pack with back EMF introduce from the motor it was found the voltage within the 6s pack can go beyond the 6s voltage.
Having said this, we would highly recommend you to use the Hercules Super BEC Pro Mini instead
http://www.western-robotics.com/WRL-HBECSPM
What we can offer is a 10% discount on this model, you will need to order this directly from us for applied discount.
Best Regards,
Western Robotics Information
WR_logo Western Robotics Ltd.
#215-12837 76th Avenue
Surrey, BC V3W2V3
Canada
Phone: 778-565-1332
info@western-robotics.com
Confidentiality Notice
This e-mail and any attachment(s) are intended for the individual or entity to which this email is addressed and may contain information that is confidential. If you are not the intended recipient or an employee or agent responsible for delivering this e-mail to the intended recipient, please be aware that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this in error, please notify the sender by return e-mail, and please delete or destroy all copies of this communication. Thank you!
Sent: October-04-16 8:36 AM
To: info@western-robotics.com
Subject: Question regarding the Super Mini BEC G2
Hello Sir / Madam,
I was going to order a WR Hercules Super Mini BEC G2 and was wondering if you could provide a few details.
1. I assume that on top of the boost mode and the lower input voltage (up to 8S), the Super Mini G2 is almost the same as the Super BEC, right? I am talking about the following two products:
https://www.amainhobbies.com/wes ... -wrl-hbecs7/p275316
https://www.amainhobbies.com/wes ... -wrl-hbecm2/p226647
2. What is the input wire gauge for the super mini G2? I saw it's 10AWG on the product picture but would like to confirm with you.
3. Is it fine that I wire this thing into one 6S battery in a 12S setup (two 6S connected in series)?
Thank you!
xxxx
