查看: 15350|回复: 83
【2018.9.3更新】【TBS Crossfire相关】---包含与TBS Crossfire相关的大部分内容
发表于 2017-10-15 23:24 | 只看该作者 |只看大图 回帖奖励 |正序浏览 |阅读模式
好久没发帖了~~~
随着最近国外视频中TBS Crossfire的出镜率增高,我整理了Youtube中
KrazyFPV对TBS Crossfire的相关视频,基本包含了对码、升级固件、天线摆放、RSSI设置等大部分内容。(本帖后续不定时更新!)
英语较差的模友可登陆Youtube搜索]Krazy FPV,观看带字幕翻译的原视频。
1、两种接收机天线的固定、简版Crossfire&BF&X9D的设置
2、用X9D SD卡中的LUA对码和设置
3、
Crossfire V2接收机&KissFC的连接和在KissGUI中的设置
4、
Crossfire 接收机固件的升级
5、Crossfire接收机对码
6、映射输出通道
7、如何用TBS Crossfire在BF的OSD里设置出信号强度或者RSSI
8、V2接收天线的最佳极化
9、RSSI / Link Quality (LQ) Warning for OpenTX
TBS Crossfire – LQ monitoring
While you are flying it´s important to have a eye on your rc link.
If you are not using a osd there is a alternativ way to get noticed – with voice warnings from your taranis.
Requirements:
  • aranis x9d(+)/ X7/ x10
  • OpenTX 2.2 (or higher)
  • Crossfire 1.65 (or higher)
  • Crossfire receiver with enabled telemetry
  • If you have problems with the crsf telemetry
Information
The Crossfire can output the LQ with wider ranger (0-300%) which can´t be interpreted by OpneTX.
Therefore the splitet it in to two sensors: RLQY and RFMD.
  • RLQY: Received link quality - the ammount of the transmittet signal recived by the reciver
  • RFMD: Received frequenzy mode - to scale the 300% Crossfire LQ down to 3x 100%
RFMD 2 = 150Hz Mode
RFMD 1 = 50Hz Mode
RFMD 0 = 4Hz Mode (forced telemetry)
LQ = 0-100%
While the Crossfire is in 150Hz mode the lq doesn´t matther so there s no need to monitore the link quality. When it switches to the 50Hz mode the critical level is at 70%.
Setup
The setup for the radio is relay simple:
What they mean:
L01: Monitors the Crossfire frequency mode, activated when it´s not in 150Hz mode
L02: Activ when the Link quality drops below 80% (pre warning) AND 50 or 4 Hz mode is activ
L03: Same as L02 but with the critical warning level at 70%
L02 and L03 also got a smal delay (0.5s) to avoid warnings when the signal is only bad for a short moment.
With the logical switches the voice alerts will be triggert every time the are activ.
What they mean:
SF1: when L02 is activ, plays the selected track ones -but not at the startup
SF2: same as SF1 for the critical warning
Why to use Link quality instead of RSSI?
LQ is much more easy to monitor than RSSI. To knwo the range limit based on RSSI the noise floor need to be known as well. Noise floor depends on environment and on the components built-in the airframe. If you are not so familiar how RSSI works we recommend to use LQ.
更新RF飞控+crossfire的接线图
今后本帖将不定时更新搬运Crossfire相关视频!敬请关注!
发表于 2019-6-27 10:42 | 只看该作者
刚用黑羊外置高频头,想调整摇杆中点和行程没反应,是不是不在原来的地方调了,X9D控
81
 楼主| 发表于 2019-2-1 00:09 | 只看该作者
晓然 发表于 2019-1-24 01:21
问一下rf飞控无osd版本的,控制图传频点时用的是什么脚本?图传的smatraudio线接在cf接收机上还是飞控上?
你是想用CF调图传还是用遥控器调图传?
发表于 2019-1-24 01:21 | 只看该作者
79
 楼主| 发表于 2018-12-27 20:59 | 只看该作者
joe0612 发表于 2018-12-24 23:21
我的这页设置找不到 RFMD 跟 RQly 这两个选项 怎么解决呢? 谢谢~
肯定有的  仔细找找
78
发表于 2018-12-24 23:21 | 只看该作者
77
 楼主| 发表于 2018-10-24 22:44 | 只看该作者
大婷妹妹 发表于 2018-10-24 12:50
主要是不会英文玩不转开源控
X9D在穿越里占不了50%也能占个40%的比例吧   而且论坛里啊、QQ群里啥的都有中文说明书和教程,会不会英文真的不是那么重要。
76
发表于 2018-10-24 12:50 | 只看该作者
xgs610 发表于 2018-10-24 08:04
觉得贵那就用x7配r9m
主要是不会英文玩不转开源控
 楼主| 发表于 2018-10-24 08:04 | 只看该作者
大婷妹妹 发表于 2018-10-23 14:56
贵贵贵,有没有中文控可以像x9d一样支持别的高频头
觉得贵那就用x7配r9m
发表于 2018-10-23 14:56 | 只看该作者
发表于 2018-10-17 12:50 | 只看该作者
先顶了,买了黑羊的高频头,一头雾水什么都不懂
发表于 2018-2-13 10:14 | 只看该作者
xgs610 发表于 2018-2-13 03:29
嗯,我先试试手里的rf one,好多用过的人对rf评价都很高,亲自感受下~
rf飞控工作频率很高(双32K),对振动很敏感,要求fc必须软装,甚至电机也要软装。
71
 楼主| 发表于 2018-2-13 03:29 | 只看该作者
数不清 发表于 2018-2-12 11:08
新款还在预售,中国新年后才按订单发货,国内估计还要晚一些。
70
发表于 2018-2-12 11:08 | 只看该作者
xgs610 发表于 2018-2-12 09:54
带osd的现在国内好像还没货  之前买了个rf飞控  一直没捣鼓  准备过年装机
69
 楼主| 发表于 2018-2-12 09:54 | 只看该作者
数不清 发表于 2018-2-11 11:41
RaceFlight 即将发售的新款 RevoltOSD 飞控有OSD芯片,售价 $44.99
发表于 2018-2-11 11:41 | 只看该作者
xgs610 发表于 2018-2-10 23:04
还没用过smartaudio  学习受教了
https://shop.raceflight.com/product/raceflight-revoltosd/
67
 楼主| 发表于 2018-2-10 23:04 | 只看该作者
数不清 发表于 2018-2-5 19:24
这款飞控不带OSD,遥控可以通过LUA脚本(smartaudio)来调整图传参数。
66
发表于 2018-2-7 11:36 | 只看该作者
reach3 发表于 2018-2-6 22:22
对对,图传当然用smartaudio接飞控,我是问crossfire难道也要用smartaudio接飞控?
LUA脚本能侦测到CF,也可以进入设置,不接SA看不到。
65
发表于 2018-2-6 22:22 | 只看该作者
数不清 发表于 2018-2-6 21:27
1.smartaudio协议传递数据还能传递音频信号,可以把摄像头或MIC的音频通过图传发射出去。2.smartaudio协 ...
发表于 2018-2-6 21:27 | 只看该作者
reach3 发表于 2018-2-5 23:44
crossfire还要用smartaudio?它不是tx,rx一对线,双向的吗?
1.smartaudio协议传递数据还能传递音频信号,可以把摄像头或MIC的音频通过图传发射出去。2.smartaudio协议通过飞控设置图传频率和发射功率,CRFS并不能设置图传参数。
beteflaght的文档有介绍
https://github.com/betaflight/betaflight/wiki/Unify-Smartaudio
