查看: 852|回复: 1
佩恩控组装说明
发表于 2017-12-8 16:10 | 只看该作者 |只看大图 回帖奖励 |正序浏览 |阅读模式
Payne Simple RC is designed by Payne Pan (email: payne.pan@qq.com) as for learning and simple DIY. It is based on Arudino Pro mini, the source is shared on "https://pan.baidu.com/s/1nuNP3tB#list/path=%2F"
(due to GFW,I cannot put it into github), Since it is for study, no license, nor warranty granted.
e
Open the source in Arduino IDE, chose board "Arudino Pro or Pro min". processor as "ATmega 328p(5v,16M)",then you can compile and upload the firware, Hope you enjoy it!
 楼主| 发表于 2017-12-8 16:15 | 只看该作者
焊接教程如下:
