GM01, a kind of tail-holding gyro with simple operation, is mainly designed for the tail motor series RC helicopters, and can work with the external ESC to make the flight much more stable.
2).It is composed of ultra mini sensor and controller which is equipped with sensitivity adjustment (SENS.) and tail motor?s rotary rate adjustment (ROT.)
华科尔的这个GM01看看应该可以用的,原来四合一只要把接收拆出来! |
