前言:
长久一来,线操纵垂尾一直是固定的。但在不同飞行姿态下,要求垂尾的尾力臂控制力度不同。比如在俯仰姿态下,要求垂尾有更大的偏转角度来保证机身姿态与平飞一样,而且有更大的向外张力。不同姿态下垂尾角度变化一直是缺乏有效控制手段。
国内有人设计了三线控制方式。第三根线主要就是控制垂尾偏转角度。但手上动作变化大,导致垂尾偏转角度不一致。而且增加一根操纵钢丝势必增加很大飞行阻力。
下面介绍的联动机构实际上是垂尾与平尾随动。这样便于调整,对飞机影响不大。原文对垂尾多种不同的初始设置进行了研究,很有借鉴意义。附原文(请高手翻译)
Al Rabe's Movable Rudder setup
A description by Al Rabe of how he set up the Moveable Rudder on his latest masterpiece
There is still a great deal of confusion about the use and adjustment of the movable rudder (actually, I never called it a "Rabe Rudder"). I thought the article in Stunt News Nov/Dec 2001 issue covered the subject well. It answered all the theoretical questions about how it works and described how to install and adjust one.
Questions still arise. Without going into great detail of explanation about the use of the moving rudder, I thought I'd simply show some of my trim reasoning.
Photo 1.
This simply shows a typical installation of the movable rudder on Snaggletooth. The point here is that the elevator end of the pushrod is below and about 45 degrees behind the elevator hinge line. It is simply a cut off and drilled plastic horn.
Photo 2.
This photo shows several elevator end horns and their pushrods. The middle one is Sanggletooth's first
Photo 3.
This photo shows a template custom made for Snaggletooth, for visualizing and adjusting its rudder movement. There was a similar template published on the Mustunt plans and a photo of a template in the Stunt News article. The photos of my Snaggletooth template here demonstrate my belief in the use of a similar template for systematic trimming adjustments. Without systematic adjustments, satisfactory operation of the rudder is a matter of luck. If the movable rudder doesn't meet expectations, one can always claim the thing obviously doesn't work
Photo 4.
This photo shows my best guess at a good setting and the adjustments I used for the first flight. "0" on the template is zero offset of the rudder when the elevators are at neutral. Each mark is 1/8", but, to simplify explanation, I'll call each mark a "unit". In this case I set the rudder to be 1 1/2 unit offset with the elevators at neutral. Why? I simply like a bit of rudder offset.
Photo 5.
This photo shows the rudder, on full "up", has moved to minus 1/2 unit, inboard, or left two units total from the neutral elevator position.
Photo 6.
This photo shows the rudder position with the elevators full "down". In this photo the rudder is at 5 1/2 units. It has moved outboard, or right, four units from its elevator neutral position. That is a ratio of two to one for outboard versus inboard movement from elevator neutral. I typically use a ratio of three to one. The ratio is dependent on the location of the horn "pickup" at the elevator end of the pushrod. In any case, it is much better to use too little movement as opposed to too much. In the case of Snaggletooth, There is more rudder movement than I'd recommend. The reason being that I was running a very large 14 1/2" prop and anticipated much more than normal gyroscopic precession. This would require more correcting rudder movement than would be typical. A typical rudder initial setting for most stunt ships would be to move one unit (1/8") inboard of elevator neutral position and three units outboard of the elevator neutral position for a typical three to one ratio of relatively small movements.
On its first flights, Snaggletooth had a bit of wobble in outside corners with these settings, otherwise it seemed OK. I figured it needed more right rudder on "down". I moved the pushrod in one hole on the rudder horn to make the rudder more sensitive. It would move more on both "up" and "down". The next flights proved the outside corners smooth now, with the rudder on "down" at eight units. I was also beginning to pick up a bit of slack on the first loop of the cloverleaf, an inside loop. I tried another hole inboard on the rudder horn and found no improvement in the outsides and a definite loss of tension in that cloverleaf first loop. The use of rudder movement inboard of rudder neutral may be appropriate and is theoretically correct to compensate for the outward yaw on inside, nose up, pitching maneuvers. It just happens that Snaggletooth doesn't like it. Theoretical correctness or no, practical trimming requires that observed deficiencies be addressed. One possible solution to the problem would be to simply return the pushrod to the outside hole on the rudder horn and crank in more offset which would give less inboard rudder position on "up" and more outboard rudder position on "down". This would have certainly given an improvement in both inside and outside corners, but would result in more offset with elevator neutral than I wanted. Another possibility would be to change the ratio of inboard movement to outboard movement so that the rudder would move less toward the inside and more toward the outside. This is accomplished by moving the elevator end of the rudder pushrod farther from the hinge line. If this is done to an extreme, the geometry might even cause a bit of outboard movement on "up" in addition to more outboard, or right, rudder on "down". I don't recommend this degree of asymmetry and have never had to use it in the past to obtain optimum trim. Snaggletooth, however, doesn't like any inboard movement of the rudder from the neutral rudder position on "up". It tends to weaken that first cloverleaf loop. Everywhere else is OK and I can "whip" that entry, but it is better to trim rather than to rely on "whipping".
Photo 7.
this shows a rather extreme position of the elevator end of the rudder pushrod. The pickup has been mover about 1/4" aft, increasing the angle downward and back from the elevator hinge line to about 60 degrees. I don't recommend using this much asymmetry. It has never been necessary in the past. AND, I haven't flown it yet with this setting, which may prove to have too much asymmetry. I'll fly it and make further adjustments as necessary. I think that starting off with this much asymmetry a poor choice, and, you'll notice, I didn't.
Photo 8.
This photo shows the rudder offset with the elevators neutral is still about 1 1/2 unit. this is the same as the initial installation.
Photo 9.
Check this out. the rudder started the move slightly inboard as the elevators moved "up" and then moved slightly, about 1/2 unit out. This gives little or no position change of the rudder on "up".
Photo 10.
This final photo shows the rudder moving to about eight units when the elevators are "down". From trimming trials so far, this should be approximately the desired position of the rudder on "down". The increase in asymmetry has had this net effect. The overall rudder offset is the same as I started with. The right rudder position on full "down" is about where I liked it when I tried more sensitivity. The left rudder movement on "up" has effectively been eliminated. This combination should give me that smooth, wobble free, and solid outsides, and elimination of any possible harm to the cloverleaf first loop from inboard movement of the rudder.
It should be noted that there are three separate adjustments possible with this simple device. Overall rudder offset, rudder movement inboard on "up", and rudder movement outboard on "down" are individually adjustable without interfering with preferred adjustments of the other two.,br. In the example above, I managed to reduce Inboard movement and increase outboard movement without changing the base rudder offset. Optimum adjustment of the movable rudder requires a thoughtful understanding of its capability and a template. Movable rudders added to airplanes without adjustment aren't likely to perform well.
........................................................................................需待“总结”。。。。。。。。。。。。。。。。。
[ 本帖最后由 生活是一盘菜 于 2010-6-8 23:00 编辑 ] |
