查看: 13827|回复: 50
[原创] T8FG Service menu 工程菜单
发表于 2010-6-17 01:58 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
T8FG service Menu (successed)
Greate news for Futaba T8FG users.
After few days institude on T8FG firmware and it's tinyfs structures, I successed entered T8FG service
menu and access all service futures (most import function is stick recalibration).
(based on the hard study of ajd999 on helifreak forum. oringal link: http://helifreak.com/showthread.php?t=217886)
Here is the detail procedure.
1. Get a empty SD card. (zero fill it if nessesary)
2. Insert into T8FG and format the card as prompted.
3. Copy a model to the SD card. (no matter the name or the type it is)
4. power off the TX and put the SD into a SD card reader on your computer.
5. use any HEX edit tool (I'm using ultraedit) to open tinyfs.bin file on the root directory of the
card. (you may need to enable show hidden files on your explorer options).
5.1 make changes to following addressed.
00200: 23 (original 43, or 03 if card is empty)
02200: 02 (original 00 if empty)
06480: 00 00 1F 77 93 D9 00 00 00 00 00 13 00 01 00 00 ( original all 00 or FF )
82E00: 54 38 46 47 20 20 54 45 53 54 28 4E 4F 52 45 53 45 54 29 00 ( stands for 'T8FG TEST
(NORESET)')
* 82E00 maybe different for you card vendor or capacity(I'm using APCER 1G 60x SD card). To find this
address. Find hex string "54 00 38 00 46 00 47 00", (should occure only once if the card was proper zero
filled), the leading two bytes beforce the address occured the match hex string will be 00 00 or 00 01.
(depends the model type you just created or copied in step 3. 00 00 for air plan, 00 01 for helicopter),
at the beginning of 00 00 or 00 01, replace with "T8FG TEST(NORESET)" (note there were two spaces
betwin T8FG and TEST.)
6. Insert the card into T8FG and poweron. you will get into service menu. (don't touch the update switch
besides the SD slot)
7. do some interesting things
*** WARRING !!!! OWN YOUR RISK TO DO THIS, EVERY STEP AFTER STEP 6 MAY DISTORY YOU TRANSMITTER ***
in addtion to 'T8FG TEST(NORESET)' there are following different "filenames" maybe used to enter different service menus.
'T8FG  TEST(NORESET)' - Shows all service menus and allows making all the changes.
'T8FG  TEST(LIMIT  )' - Shows only a sub-set of service menus, with limited editing possibilities. E.g. Cannot change the product id, band, area...
'T8FG  TEST(RST SS )' - Don't Known SS stands for
'FX-20 TEST(RST SS )' - Do service FX-20, Don't know SS.
'T8FG  TEST(RST PCM)' - Don't Known detail, maybe reset PCM module locate
'FX-20 TEST(RST PCM )' - Do service FX-20, Reset PCM Module.
'T8FG  TEST(NOEDIT )' - Shows all service menues, but prevents any changes. Includes an RF test screen.
'T8FG  TEST(TELEC )'  - Don't known what's purpose
'T8FG SCREEN SHOT ' - A screen shot of TX can be made with SW-H. Screen shots are stored on SD card and can be extracted with ffs.exe tool.
'T8FG  TEST SHOT    '  - maybe simular to screen shot
最新更新 (2010-6-18)
8FG/12FG Service SD Card 自动创建程序
http://starmoon.org.cn/share/software/RC/T8FGService.rar
[ 本帖最后由 starmoon 于 2010-6-18 22:51 编辑 ]
发表于 2011-3-10 16:58 | 只看该作者
飘过
50
发表于 2010-12-18 20:32 | 只看该作者
好帖
49
发表于 2010-12-10 11:08 | 只看该作者
请教LZ
太利害了
请教LZ
我正想买T8FG 几个问题请教(都是一些小白的问题)
1.
我现在主飞固定翼,未来飞电直好用吗?
2.
日本手改美国手自己好改吗?若自己改,是不是还有保固?
3.
LZ
买这控,FUTABA的保固吗?保固多久?
4.
T8FG
只能用原装锂电吗?可否用AA电池?
小白问题请费心指教
感谢啊
48
发表于 2010-12-10 01:12 | 只看该作者
2.1的能校准吗
47
发表于 2010-12-9 23:46 | 只看该作者
这个要收藏了~~~
46
发表于 2010-8-18 19:31 | 只看该作者
好贴:em24:
45
发表于 2010-8-18 16:23 | 只看该作者
不错,好东西。
最好 有兼容 的接收机 出现啊。。
44
发表于 2010-8-5 13:38 | 只看该作者
门叔是个高人:em26: :em26:
43
发表于 2010-6-25 12:20 | 只看该作者
我也看看 不说话  因为说不出来了
42
发表于 2010-6-24 21:51 | 只看该作者
十六进制
41
发表于 2010-6-24 11:05 | 只看该作者
看贴就回
发表于 2010-6-22 00:11 | 只看该作者
不得不顶的好贴,感谢楼主的无私奉献
发表于 2010-6-21 15:15 | 只看该作者
不明白,进入工程模式后控的功能就提升了还是。。麻烦知道的人指点一下。。正准备进T8FG
发表于 2010-6-21 11:44 | 只看该作者
深奥啊!
发表于 2010-6-21 10:30 | 只看该作者
好贴:em26:
发表于 2010-6-20 09:48 | 只看该作者
小弟没看懂啊 :em19:
发表于 2010-6-20 00:16 | 只看该作者
不懂英文啊,惭愧
 楼主| 发表于 2010-6-19 21:53 | 只看该作者
截屏上有字
发表于 2010-6-19 12:39 | 只看该作者
能说明一下菜单1-9都是些什么功能吗?
