查看: 21947|回复: 76
T8FG/T12FG 工程模式SD卡自动创建程序
发表于 2010-6-18 22:54 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
Tools to create futaba T8FG service activator SD card.
1. Make sure the SD card was proper formatted by T8FG trasmitter.
(No matter there is model data in it)
2. Insert card to SD card reader and run T8FGService.exe
3. Select the correct drive where your SD card is in.
4. Click ok and wait the procedure complete.
5. Eject the card and insert into T8FG
6. Powre on T8FG and the service menu appears automaticly.
7. When your want reuse the SD card in T8FG to store model data. Just delete TINYFS.IMG in card root directory or format the card in OS.
** WARRING: OWN YOUR RISK TO MODIFY SERVICE MENU SETTINGS **
Futaba T8FG 工程模式激活工具
1. 把SD卡放入控中格式化 (无需空卡)
2. 把SD卡放入读卡器,并启动 T8FGService.exe 程序
3. 选择SD卡对应的驱动器符
4. 点击“OK”等操作完成
5. 弹出SD卡,插入T8FG中
6. 打开T8FG电源,工程菜单会自动显示
7. 如果还需要使用这张卡存放模型数据,删除TINYFS.IMG文件或在操作系统中格式化。
** 警告:小心使用工程菜单,自担风险 **
modify KEY.dat file to do other function. (Any string else to disable service function)
'T8FG  TEST(NORESET)' - Shows all service menus and allows making all the changes.
'T8FG  TEST(LIMIT  )' - Shows only a sub-set of service menus, with limited editing possibilities. E.g. Cannot change the product id, band, area...
'T8FG  TEST(RST SS )' - Don't Known SS stands for
'FX-20 TEST(RST SS )' - Do service FX-20, Don't know SS.
'T8FG  TEST(RST PCM)' - Don't Known detail, maybe reset PCM module locate
'FX-20 TEST(RST PCM)' - Do service FX-20, Reset PCM Module.
'T8FG  TEST(NOEDIT )' - Shows all service menues, but prevents any changes. Includes an RF test screen.
'T8FG  TEST(TELEC  )'  - Don't known what's purpose
'T8FG SCREEN SHOT   ' - A screen shot of TX can be made with SW-H. Screen shots are stored on SD card and can be extracted with ffs.exe tool.
'T8FG  TEST SHOT    '  - maybe simular to screen shot
This program can be used for T12FG too. Just use following code in KEY.dat instead.
'T12FG TEST(NORESET)' - Shows all service menus and allows making all the changes.
'T12FG TEST(LIMIT  )' - Shows only a sub-set of service menus, with limited editing possibilities. E.g. Cannot change the product id, band, area...
'T12FG TEST(RESET  )' - Hard reset of the TX. All memory is cleared, total power on time is reset, product id is cleared, stick calibration is reset...
'FX-30 TEST(RESET  )' - I don't have FX-30, so I never tried it. Don't know what it does.
'T12FG TEST(NOEDIT )' - Shows all service menues, but prevents any changes. Includes an RF test screen.
'T12FG SCREEN SHOT  ' - A screen shot of TX can be made with SW-H. Screen shots are stored on SD card and can be extracted with ffs.exe tool.
下 载地址:
http://starmoon.org.cn/share/software/RC/T8FGService.rar
发表于 2020-4-15 18:45 | 只看该作者
链接打不开,能重发一下吗?谢谢
76
发表于 2012-10-22 22:27 | 只看该作者
不错,收藏了!
75
发表于 2011-9-25 19:12 | 只看该作者
原帖由 starmoon 于 2010-6-18 22:54 发表
2. Insert card to SD card reader and ...
没资源 下 载不了啊
74
发表于 2011-7-21 14:02 | 只看该作者
12fg  也能用吗?
73
发表于 2011-1-14 21:09 | 只看该作者
:em26:
72
发表于 2011-1-7 16:48 | 只看该作者
:em26: :em26:
71
发表于 2010-12-20 18:55 | 只看该作者
创建什么程序?,,,,:em23:
70
发表于 2010-12-10 18:30 | 只看该作者
非常感谢!!
69
发表于 2010-12-10 17:30 | 只看该作者
成功进入,校准成功,感谢lz的分享。8fg的校准,升级以后,手痒,把12z也搞了一遍,爽!
期待2.1的进入程序!
68
发表于 2010-11-12 00:43 | 只看该作者
:em26:
67
发表于 2010-10-15 23:16 | 只看该作者
求starmoon继续研究啊
66
发表于 2010-10-15 20:50 | 只看该作者
原帖由 阿琨 于 2010-9-12 14:24 发表
原版8FG,通过STARMOON贴的帮助,校准了摇杆,很成功!
汇报一个新情况,,FUTABA出了8FG的V2.0软件,我升级成功后!再次用LZ大人的方法插入已经带工程模式开启的SD卡,开控,左边灯亮,屏幕不亮,无任何显示,反复 ...
同问
65
发表于 2010-10-4 08:47 | 只看该作者
进入工程模式后,老是停留在第一页,搞了几次,变成触摸键锁死,有没有解救方法!!:em25:
[ 本帖最后由 yylch 于 2010-10-4 08:48 编辑 ]
64
发表于 2010-10-3 12:38 | 只看该作者
是否升级后,全部数据会重新恢复出厂设置?
63
发表于 2010-9-18 23:24 | 只看该作者
求解。。。。。。。。。。。。。。。!!!!!!!!!!!!!!!!
62
发表于 2010-9-13 22:22 | 只看该作者
61
发表于 2010-9-12 14:24 | 只看该作者
汇报一个新情况,,FUTABA出了8FG的V2.0软件,我升级成功后!再次用LZ大人的方法插入已经带工程模式开启的SD卡,开控,左边灯亮,屏幕不亮,无任何显示,反复试过,依然这样
不知是不是V2.0不能用这种方法了!!!!
求解啊!!!
60
发表于 2010-9-11 21:40 | 只看该作者
执着地顶起来
59
发表于 2010-9-3 00:59 | 只看该作者
不怎样,再开就回到初始模式
你是想问更新过程中断电会怎样把,,,这个没敢试:em15:
