两种舵机的参数贴下面让更多人了解,这几个舵机准备用在新装的90机器上,DS670十字盘三个,DS760做尾舵机,另外一个做油门了。Danny!
等装好机器了上些视频再与大家分享!:loveliness:
A:
MKS DS-670 STD Digital Servo
Dual Ball Bearings / Titanium Gears
Stall Torque (6.0V): 15.72 kg-cm (218.35 oz/in)
Specification:
Dead band: 0.001ms (Default)
Control System: +Pulse Width Control
Working frequence: 333Hz
(RX) Required Pulse: 3.0~5.0 Volt Peak to Peak Square Wave
Operating Voltage: 4.8~6.0 V DC Volts
Operating Temperature Range: -10 to + 60 Degree C
Operating Speed (4.8V): 0.111 sec/60° degrees at no load
Operating Speed (6.0V): 0.089 sec/60° degrees at no load
Stall Torque (4.8V): 12.58 kg-cm (174.73 oz/in)
360° Modifiable: NO
Motor Type: Coreless Motor
Potentiometer Drive: Direct Drive
Driver Type: FET
Bearing Type: Dual Ball Bearings
Gear Type: Titanium Gears
Case: Alum-magnesium alloy shell (metal upper)
Programmable: NO
B:
MKS DS-760 STD Digital Servo
Super Narrow Pulse 760us with AVCS
Operating Speed (6.0V): 0.027sec/60°
INCLUDES
Specification
Working frequence: 760us /560Mhz
(RX) Required Pulse: 3.0~5.0V Peak to Peak Square Wave
Operating Voltage: 4.8~6.0V DC Volts
Operating Speed (4.8V): 0.034sec 60° degrees at no load
Operating Speed (6.0V): 0.027sec/60° degrees at no load
Stall Torque (4.8V): 3.9kg-cm (54.17oz/in)
Stall Torque (6.0V): 4.9kg-cm (67.78oz/in)
360?Modifiable: NO
Driver Type: FET
Programmable: NO
[ 本帖最后由 rcop 于 2010-7-28 17:43 编辑 ] |
(159.09 KB, 下载次数: 54)
(159.09 KB, 下载次数: 49)
(116.71 KB, 下载次数: 67)
(86.96 KB, 下载次数: 52)
(95.41 KB, 下载次数: 65)
(102.97 KB, 下载次数: 66)
(120.21 KB, 下载次数: 48)
(119.22 KB, 下载次数: 70)
(126.03 KB, 下载次数: 66)
(117.08 KB, 下载次数: 64)
(120.82 KB, 下载次数: 54)
(123.12 KB, 下载次数: 52)
(58.06 KB, 下载次数: 48)
