查看: 1032|回复: 3
ROBOFORM 22高频功放板
发表于 2010-9-24 23:00 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
ROBOFORM 22
file:///F:/产品/电加工/电脉冲/ROBOFORM%2022/ROBOFORM%2022.files/bpixel.gif
Simple perfection you can bank on
[url=]file:///F:/产品/电加工/电脉冲/ROBOFORM%2022/ROBOFORM%2022.files/prod_die_mres_22.jpg[/url]
  • Economical entry level CNC EDM
  • Strong mechanical design
  • High positioning accuracy with linear glass scales
  • Well proven generator
  • Simple CNC controller
Machine
X, Y, Z travel
mm
300 x 250 x 250
Max. workpiece weight
kg
200
Max. electrode weight
kg
Min./max. chuck to table distance
mm
145/395
Positioning resolution
µm
0.5
Weight of installation without dielectric
kg
900
Measuring device
Linear glass scales
Worktank
Type of tank
Fixed tank
Work tank dimensions  Width x Depth x Height
940 x 530 x 330
Max. dielectric height
mm
290
Work table dimensions Width x Depth
mm
400 x 300
Dielectric System
Filtering system
Total reservoir capacity
l
248
Generator
Standard machining current
A
Autoadaptative Control/Automatic machining optimization
Standard
Numerical Control
4 axes
Program Expert/Programming system
Standard
DNC1
Standard
Options
C axis
Max electrode weight 10kg
Linear tool changer
Erowa, System 3r, Mecatool and Hirschmann
Rotary tool changer
System 3r Macro/Combi
Additional generator module
A
Polishing
CH 0/Ra 0.1µm
file:///F:/产品/电加工/电脉冲/ROBOFORM%2022/ROBOFORM%2022.files/spacer.gif
The technical data are not binding. They are not warranted characteristics and are subject to change.
Please consult the General Sales Conditions of Charmilles Technologies SA.
last updated 10.07.00.
file:///F:/产品/电加工/电脉冲/ROBOFORM%2022/ROBOFORM%2022.files/close.gif
发表于 2010-10-2 12:15 | 只看该作者
奇怪,我扫描不出这么好的效果,楼上是用什么扫描仪扫描的?
 楼主| 发表于 2010-9-24 23:10 | 只看该作者
脉冲板(扫描仪扫后拼图)
脉冲板(扫描仪扫后拼图)
 楼主| 发表于 2010-9-24 23:04 | 只看该作者
整机
整机
