查看: 833|回复: 0
请教以下有刷四通370马达的型号
发表于 2011-12-8 09:33 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
Motor............Volts...Turns...Diameter...Mabuchi part #...No Load rpm
RK370-2870......7.2...70...0.28mm......RK370SD-2870....16500
GWS EM300H...7.2...45...0.40mm......RK370SD-4045....22950
GWS EM300......7.2...33...0.45mm......RK370SD-4533....34000
GWS EM350......6.0...28...0.50mm......RK370SD-5028....35000
BIG LAMA:RK370SD-4045
BEE 2:?
CUPID V3:?
CB180D:?
