查看: 1338|回复: 0
中美大合照 (APM2 零件编)
发表于 2012-5-16 13:52 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
今天刚好收到美国和中 国订的APM 零件,快快来个大合照吧!
左边两个是中 国雷迅,右边两个是美国DIYdrones!
3DR Radio USB-915 Mhz "地面" "天空 模块
  • Very small size
  • Light weight (under 4 grams without antenna)
  • Available in 900MHz MHz
  • Receiver sensitivity to -121 dBm
  • Transmit power up to 20dBm (100mW)
  • Transparent serial link
  • Air data rates up to 250kbps
  • MAVLink protocol framing and status reporting
  • Frequency hopping spread spectrum (FHSS)
  • Adaptive time division multiplexing (TDM)
  • Support for LBT and AFA
  • Configurable duty cycle
  • Built in error correcting code (can correct up to 25% data bit errors)
  • Demonstrated range of several kilometers with a small omni antenna
  • Can be used with a bi-directional amplifier for even more range
  • Open source firmware
  • AT commands for radio configuration
  • RT commands for remote radio configuration
  • Adaptive flow control when used with APM
  • Based on HM-TRP radio modules, with Si1000 8051 micro-controller and Si4432 radio module
价钱比Xbee平,但得100mw,只适合玩四轴,加booster去到500-1000mw就可以玩飞机。有无师兄提供booster的连结?
[ 本帖最后由 monkey1 于 2012-5-16 15:54 编辑 ]
