查看: 932|回复: 1
mwc gps home
发表于 2013-4-23 11:25 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
谁知道设置GPSHOME返航时速度的那段代码在哪???
还有: /* GPS navigation can control the heading */
    #define NAV_CONTROLS_HEADING       true      // copter faces toward the navigation point, maghold must be enabled for it
    #define NAV_TAIL_FIRST             false     // true - copter comes in with tail first
    #define NAV_SET_TAKEOFF_HEADING    true      // true - when copter arrives to home position it rotates it's head to takeoff direction
这三个是机头朝向的 不需要哪个直接注释掉就可以????
谢谢了`~~~
 楼主| 发表于 2013-4-23 11:58 | 只看该作者
刚又看了下代码感觉就是这两句的一句        #define GPS_WP_RADIUS              200       // if we are within this distance to a waypoint then we consider it reached (distance is in cm)
#define NAV_SLEW_RATE              30        // Adds a rate control to nav output, will smoothen out nav angle spikes
完了改了试试看!!
