查看: 909|回复: 5
9X2
发表于 2008-4-29 01:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请问我的9X2开得时间长时候后面的高频头有点点发热是不是正常的?大家有发现这个问题吗?
发表于 2008-4-29 08:28 | 只看该作者
正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常正常
发表于 2008-4-29 09:13 | 只看该作者
正常
发表于 2008-4-29 18:10 | 只看该作者
而且,不拉出天线的话会更加烫。
发表于 2008-4-29 22:49 | 只看该作者
相当正常!要不热那才不正常呢!
发表于 2008-4-29 23:58 | 只看该作者
9X2还是把出一点天线比较好。
