查看: 1005|回复: 11
hitec laser 6 VS futaba6EXA?
发表于 2005-1-28 02:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
I want to buy one system. Actually I will use it for my tiger cat first.
So which one is better?
http://www2.towerhobbies.com/cgi ... ;I=LXCZR659&P=0
http://www.hitecrcd.com/product_fs.htm
hitec laser 6(75GHZ for surface) is 138$ and futaba 6EXA (72MHz)is 155$.
发表于 2005-1-28 09:16 | 只看该作者
看不懂:em15:
发表于 2005-1-28 09:17 | 只看该作者
may be futaba6exa is better for you......
by the way, what is tiger cat ?
 楼主| 发表于 2005-1-28 12:03 | 只看该作者
I want to register as tigerking, but somebody take it, so I have to become tiger_cat.
发表于 2005-1-28 12:22 | 只看该作者
no...
on the top you said "Actually I will use it for my tiger cat first." here what's the tiger cat? a aircraft? boat? car?
发表于 2005-1-28 22:50 | 只看该作者
虎王?tank?
 楼主| 发表于 2005-1-28 23:11 | 只看该作者
oops, my mistake. It should be tiger tank.:em05:
发表于 2005-1-29 00:01 | 只看该作者
yes!
发表于 2005-1-30 10:45 | 只看该作者
oops......tank
发表于 2009-4-6 00:39 | 只看该作者
:em13: :em16: :em15:
发表于 2009-4-6 15:57 | 只看该作者
futaba 14mz would be better!:em15: :em15: :em15:
