用ARTCAM搞了几个浮雕,输出代码给雕刻机干活,发现参数根本与机器不同,还扰乱了设置的参数(原来走1就是1mm的,变成20多mm)请老鸟们帮帮忙,O(∩_∩)O谢谢!
这是我输出的代码,格式是.tap
G91
T1
G1M04R
G1X0Y0Z0R
G1Z-590F39.4
G1X15
X23606
Y13
Y26
X-14
X-23606
Y13
Y27
X14
X23606
Y13
Y26
X-14
X-23606
Y13
Y26
X14
X23606
Y13
Y27
X-14
X-23606
Y13
Y26
X14
X23606
Y13
Y26
X-14
X-23606
这是另一个格式的代码.nnc
O1234(2)
N3 G17 G90 G20 G40 M92 T0
N4 G08 P1
N5 G91 G28 Z0 M95
(MATERIALundefined
( X MIN:0.000 Y MIN:0.000 Z MIN:0.000)
( X MAX:2.362 Y MAX:2.362 Z MAX:0.034)
( X SIZE:2.362 Y SIZE:2.362 Z SIZE:0.034)
( THICKNESS:0.000)
(FIRST TOOL INFORMATION)
( TOOL NUMBER:11)
( DESCRIPTION:龙凤2)
(FEED RATES IN INCHES PER MINUTE)
( CUTTING FEED RATE:39)
( PLUNGE FEED RATE :39)
( RAPID FEED RATE :9999)
( SPINDLE SPEED :S10000 r.p.m)
/N22 T11
/N23 M13 S10000
/N24 G0 G90 G54
/N25 M11
/N26 G43 H11 Z0.0787
N27 G0 X0.0000 Y0.0000 Z0.0787
N28 G1 Z0.0197 F39.4
N29 G1 X0.0015
N30 X2.3622
N31 Y0.0014
N32 Y0.0040
N33 X2.3607
N34 X0.0000
N35 Y0.0053
N36 Y0.0079
N37 X0.0015
