AR6110/6110E 有一个红灯:请问有人知道这具体是干什么用的吗?
Red LED Hold Indicator
The AR6110/AR6110e features a red LED that indicates the number of holds that have occurred since
the receiver was last powered on. The LED will flash the number of holds then pause (e.g., flash,
flash, flash, pause, flash, flash, flash, pause indicates three holds occurred since the receiver was last
turned on). Note that holds are reset to zero when the receiver is turned off. During the first flights of a
new airplane, it’s recommended to check the red LED hold indicator. If it’s flashing, it’s important to
optimize the installation (move or reposition antennas) until no hold occurs. On later flights, the LED
Hold Indicator can be used to confirm RF link performance. |
