查看: 5140|回复: 33
[室内机] 地平线小门板,17日添加原型机视频、图纸
发表于 2012-12-16 16:18 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
地平线2.7克小接收机,7mm电机;140mm 1s锂电池,全重15克
][media=x,500,375]
参与人数 3威望 +6 收起 理由
老兵新传1 + 2 画外解说很给力!
weilung + 2 赞一个!
xcctb + 2 很给力!
 楼主| 发表于 2012-12-16 16:25 | 只看该作者
沙发自己坐;小孩手抖,手机象素也不高,大家凑活看看
发表于 2012-12-16 16:31 | 只看该作者
发表于 2012-12-16 16:38 | 只看该作者
发表于 2012-12-16 16:51 | 只看该作者
好门板
发表于 2012-12-16 17:53 | 只看该作者
不错的飞板
发表于 2012-12-16 18:45 | 只看该作者
好门板
发表于 2012-12-16 19:09 | 只看该作者
支持
发表于 2012-12-16 21:27 | 只看该作者
视频前的广告吓死人
发表于 2012-12-17 01:12 | 只看该作者
真棒,是群里的兄弟吗?有时间上个三围啊。
发表于 2012-12-17 01:13 | 只看该作者
楼主可以试试地平线的三轴,飞行姿态会更稳些、
 楼主| 发表于 2012-12-17 13:43 | 只看该作者
三轴前段时间没入,等老大进货
发表于 2012-12-17 14:35 | 只看该作者
这个好玩儿。
顶!
 楼主| 发表于 2012-12-17 15:12 | 只看该作者
原型机奉上:
ZIPPY Indoor EPP tough little guy and a real performer
Hi Guys
I wanted to offer a very nice little gym flyer that can be very tame when in a high alpha flying position but can turn into a real screamer .It can roll and loop like a crazy thing when called apon.
This is a design influenced by Leadfeathers PbF which in turn was based on a Pizza Box Flyer.This design is the culmination of having built 6 or more of the various size PbF s.
Here are some of the particulars.
6 mm wire cut EPP
3- 3.6 servos
10 gram turnigy 18-2900 motor (a 18-2000 will do the job as well with 7 " prop)
6X3 GWS DD prop
6 amp ESC
2s 360 MAH battery
Orange 2.4 receiver with case removed
3.5 ounces AUW with battery
1.5 mm carbon rod for push rods
1.5 mm carbon rod for axle 10 1/2 inches
1.5 mm carbon rods for reinforcement 11 inches
1.5 mm carbon rod for front bumper 10 inches
In building this airplane I know that the dimensions do not have to be exact but naturally you should always try to keep it as light as possible.
One word of caution and don't ask me how I know this. When you lay out the wing go to the bottom and lightly draw in a center line .From that point measure the equal distance between points for the axyle legs .They are large and act as a rudder ,they must be put on very carefully in order to get them parralel with the center line .If they are not in alignment they will readily steer the plane off course and a great deal of rudder trimming will be necessary.
The C.G. is 5 3/8 back from the front bumper.
[media=x,500,375][/media]
 楼主| 发表于 2012-12-17 15:16 | 只看该作者
原型机图纸:大家有兴趣就跟着做一做
Plans for ZIPPY front fuse.pdf (260.14 KB, 下载次数: 123)
Plans for ZIPPY rear fuse.pdf (245.23 KB, 下载次数: 91)
Plans for ZIPPY wing.pdf (244.59 KB, 下载次数: 92)
发表于 2012-12-17 17:09 ——“来自手机” | 只看该作者
下了就要顶
发表于 2012-12-18 13:56 | 只看该作者
好门板。
发表于 2012-12-18 16:43 | 只看该作者
有好东西
发表于 2012-12-19 16:24 | 只看该作者
好玩 漫天飞门板
发表于 2012-12-19 17:33 | 只看该作者
好东东就要顶
