下一步,改善了孔和活塞,使airgraver膛卸除。 This provided an opportunity to add an extra internal chamber in the tool that is ported to the rear chamber behind the piston. 這提供了一個機會,要添加一個額外的內部會議廳的工具是移植到後方商會背後的活塞。 An extra chamber allows the piston to give more of a dead-blow impact effect. 額外的會議廳,讓活塞給更多的一條死胡同的打擊,影響效果。 Rather than two different sized bores and pistons which require two hand pieces, one size can be made to cover the power range of two. 而非兩個不同大小的孔和活塞隊需要兩個手件,其中大小,可以向包括功率範圍2 。 Additional power is attained, if needed, with an optional tungsten piston. 額外權力,是實現,如果需要,與一個可選的鎢活塞。 The weight of tungsten metal is approximately 2.5 times that of steel which means more power in the same sized package. 重量鎢金屬約2.5倍鋼這意味著更多權力,在相同的尺寸封裝。 A patent has been applied for this development. 專利已申請這方面的發展。 To change pistons, the handle is snapped off of the hand piece, the stainless piston dropped out and replaced with the tungsten piston. 要改變活塞隊,終結處理是小康的手,一塊,不銹鋼活塞淘汰,並代之以鎢活塞。 This improvement as well as the previously patented adjustable stroke length gives a vast amount of versatility. 這方面的改善,以及以前獲得專利的可調行程長度給予了大量的多功能性。 |
