遥控有两种,分别左手油门和右手油门。引用一点资料:
Snap-n-Fly comes with 3 ready to fly airplanes which are uniquely different! Each airplane has slightly different flying characteristics, but all three use the same base module!
The base module is held in magnetically, inside it is the receiver, ESC, motor, and servos. The servos magnetically snap to the control linkages. When you are done flying a plane, just simply "pop" the base module off, and remount it on one of the other planes! Change the preset mixing dial to the appropriate plane, and you are off!
This kit includes 3 built airplanes, batteries, propellers and a transmitter! Inside the transmitter is the battery charger for 2 lipo packs.Just required is 4 x AA batteries.
Specification:
Airplane model: Canard, Biplane, V-tail
Wing Span: 340, 330, 350mm
Length: 260, 300, 280mm
Weight: 18, 18.5, 17.5g
Transmitter spec.
900MHz band 8-frequency selections (Mode 1) Throttle on the Right (Mode 2) Throttle on the Left
4 proportional control channels
2 switch channels (Not used in this product)
6 mixing selections
Built-in dual-position single-cell Lipo battery charger
Power supply: 6V / 4 x AA batteries (Not included)
Receiver spec.
8 working frequencies in 900MHz band
6 mixing selections
1 single-cell Lipo power supply
Included;
1 x Base module
1 x Canard plane module
1 x Biplane module
1 x V-tail plane module
3 x Lipo batteries
1 x Spare propeller
1 x Spare motor
1 x Spare motor mount
1 x Transmitter
