返回列表 发新帖
楼主: dvdzcj
弱弱的问一下,F3C具体是怎么解释?
发表于 2010-5-29 21:45 | 只看该作者
原帖由 PROPO 于 2010-5-29 15:53 发表
回LS.3D MASTER吧。。?
总算明了点了~~~~谢啦~~~~
发表于 2010-5-31 11:50 | 只看该作者
原帖由 xuesing 于 2010-5-29 10:26 发表
Alright mate, I have drilled all the hirobo helicopter's manual into my brain to help myself to pick up the right one for my future 90 size F3C practice, and I am happy enough to share.
The Hir ...
感謝Sean分享 , 和一些其他問題
1.        2004版本的E3 VPUS WC and 2009 E3 是VPUS+SSZ5 侧板有没有差異?
2.        Freya的碳侧板设计,如果用120度十字盘是如何可以调整到没有CCPM 干涉?
diamond
发表于 2010-5-31 12:37 | 只看该作者
Good day mate,
1. No, there are no differences between the carbon frames of 2004 E3 and 2009 E3.
2. You will need 8FG/12FG/12Z/14MZ radio first if you want to follow Dr.Ben's approach, these four radios have the special Futaba's eCCPM compensation software so you can adjust the mixing rate for PIT-AIL, PIT-ELE, AIL-PIT, ELE-PIT and ELE-AIL, which are very important to keep your swash level at all the times, furthermore, the linkage compensation and the speed compensation will keep your 120 swash level as the 140 does.
For more information of Dr.Ben's approach, go to Futaba USA and follow the 14mz FAQ link, the 8FG has basically the same sort of software so you can follow it as well if you have an 8FG instead.
Enjoy
[ 本帖最后由 xuesing 于 2010-5-31 12:39 编辑 ]
发表于 2010-5-31 16:19 | 只看该作者
Thanks Sean for your kind sharing.
I have 14MZ but not yet have the chance to use of these mix program function. Thanks for your suggestion and I am going to order the Freya EX+SSZ V. Should pay more effort to build up the F3C skills.
Good day,
diamond
发表于 2010-5-31 16:47 | 只看该作者
请用中文表达:em01:
发表于 2010-6-1 10:50 | 只看该作者
原帖由 diamondtai 于 2010-5-31 16:19 发表
I have 14MZ but not yet have the chance to use of these mix program function. Thanks for your suggestion and I am going to order the Freya EX+SSZ V. Should pay mo ...
Good on you!
Cheers
Sean
