返回列表 发新帖
楼主: 茉莉素馨
牛人做的V8发动机,好像已经量产了................
 楼主| 发表于 2012-8-10 16:40 | 只看该作者
google上找到的一点资料,E文好点的模友给翻译一下吧:
     Unfortunately, the 427 engine that many of you have been so familiar with, is no longer in production. Like the V-10, most of the molds for the 427 engine were destroyed in a catastrophic fire at the foundry.
Here is the latest in the Conley line of V-8 engines. It sports the Stinger 609 name badge (6.09 cubic inches or almost 100 cc) and is the culmination of almost 30 years of knowledge gained in the designing and construction of model engines.
The new Stinger possesses no parts used in prior V-8 engines.
The bore is 1.00, with a .970 stroke. It weighs about 11.25 pounds and measures approximately 14" long (from the front timing belt to the end of the transmission), 6" wide, and 8-1/4" tall. The supercharged version will be about 10" tall.
Among the numerous innovative features like large oval shaped intake ports, "D" shaped exhaust ports, and investment cast parts, two bold attributes stand tall: the dry sump pressurized oiling system and a full ignition system. The engine even has a user replaceable oil filter.
For those of you who lack familiarity with dry sump oiling, it simply means that oil resides in a holding tank, rather than a conventional oil pan, which circulates throughout the engine.
The oil that does collect in the pan is simply pumped back to the holding tank. I have incorporated what is call a "three stage" oil pump to move all the oil. One stage is used to feed oil to the engine, whereas, the other two stages are used to remove all the accumulated oil from the pan. This is particularly important for high acceleration, cornering, or boat applications. An important side note, my test engine held about 20 lbs oil pressure at idle and 60 lbs oil pressure at 9,000 rpm.
The dry sump oiling system not only adds more oil volume but aids in engine cooling and makes sure that there is plenty of oil during hard acceleration or sharp corners. The spark plugs have a 10-40 thread. As always, the new Stinger 609 V-8 will have an electric starter as standard equipment. No hand held electric motors here, or something that fits in a box below the engine, but rather a 12 volt electric motor that is an fundamental part of the engine. It can be activated manually or via the transmitter on your remote control. The centrifugal clutch is also included. The cost of the standard engine is $5,695.00 and will show off the standard “Zoomie” style exhaust. At the present time here is a list of the options:
Exhaust manifolds, cast in 303 stainless steel......................$   279.00
Exhaust manifolds, cast in 303 stainless steel - polished ....$   559.00
Painted Valve covers and intake manifold.............................$   125.00
Supercharger installed and tested..........................................$1,695.00
High duration camshaft (installed at factory only)................$   279.00
Transmission with forward-neutral-reverse available in near future.
Each engine will be fully tested and adjusted for optimum performance. I am expecting around 5.5 hp at 9,500 rpm for the normally aspirated version and about 9 hp for the supercharged version.
Prices start at
$5,695.00
            for the non supercharged version,
plus shipping and handling.
Prices are subject to change without notice.
发表于 2012-8-10 17:14 | 只看该作者
原帖由 茉莉素馨 于 2012-8-10 05:33 发表
这是从youtube上下 载下来的视频,发在优酷上
原画版本的可以去youtube下 载:Conley Precision V8 Stinger 609
这个小V8,以及后面的变速箱实在是太精致了!!!
而且看起来已经批量化生产了
视频不会发,还请围 ...
这个……
论坛有床的人再多 也不会有人触碰这东西
不说你制作出来的东西好坏 或者能不能用
就是你用成本价 开卖 都会被 喷死
发表于 2012-8-10 19:18 | 只看该作者
500块 买不来半个汽缸
发表于 2012-8-11 00:16 | 只看该作者
:em15:   好大一张500块     不过就是500块一个 也大把人嫌贵
发表于 2012-8-11 01:37 | 只看该作者
真不能够用500块去衡量着个机器~~:em17:
个人觉得转子引擎才是皇道啊!:em15:
发表于 2012-8-11 02:16 | 只看该作者
口水洒一地
发表于 2012-8-11 06:59 | 只看该作者
sadsadsadsasa
发表于 2012-8-11 09:06 | 只看该作者
好东西,玩不起
发表于 2012-8-11 11:00 | 只看该作者
那个带瓶子和黄铜管子的是CO2发动机吗
发表于 2012-8-11 11:01 | 只看该作者
在坐的大多是想用机弄钱 恐怕单纯折腾的没几个。 搞这个发动机不一定能搞出来。
发表于 2012-8-11 11:13 | 只看该作者
做这个东西的难点在什么地方呢?曲轴?
 楼主| 发表于 2012-8-11 13:22 | 只看该作者
回复 33楼 duanyz 的帖子
加工方面应该没难度,坛子里五轴那么多,曲轴有个A轴就能出来,加工不成问题
难在,这么小的引擎,火花塞没办法做,燃烧室形状和点火等一系列控制
发表于 2012-8-11 15:57 | 只看该作者
这个多少钱啊?
发表于 2012-8-11 17:34 | 只看该作者
我们也可以做出来啊,只要有资金支援,但我们不是富二代,也不是官二代,自己还工作不久,所以还没有资金基础,国家也不会支援这种不务正业的技术,这只能说明了他们那边人比我们有钱。
