但有一个問題,因这个固件是特別為这改裝而改造的,可能因PB大大太忙,他说以后的更新板本不会再為这个再作改动了.要求各用家自巳修改.
修改程式如下:
diff -r ab395d806bed src/target/devo7e/capabilities.h
--- a/src/target/devo7e/capabilities.h Thu Feb 14 20:58:25 2013 -0800
+++ b/src/target/devo7e/capabilities.h Thu Feb 14 21:06:31 2013 -0800
@@ -7,15 +7,19 @@
CHANDEF(HOLD1)
CHANDEF(FMOD0)
CHANDEF(FMOD1)
+ CHANDEF(AIL_DR0)
+ CHANDEF(AIL_DR1)
+ CHANDEF(ELE_DR0)
+ CHANDEF(ELE_DR1)
#endif
#ifdef UNDEF_INP
#define INP_RUD_DR0 INP_HOLD0
#define INP_RUD_DR1 INP_HOLD1
-#define INP_ELE_DR0 INP_HOLD0
-#define INP_ELE_DR1 INP_HOLD1
-#define INP_AIL_DR0 INP_HOLD0
-#define INP_AIL_DR1 INP_HOLD1
+//#define INP_ELE_DR0 INP_HOLD0
+//#define INP_ELE_DR1 INP_HOLD1
+//#define INP_AIL_DR0 INP_HOLD0
+//#define INP_AIL
In linux you would normally copy that to a 'file.patch' then from the deviation dir, run:
patch -p1 < file.patch
但因技術所限,这修改我是應付不來的了.但望有能者,或請商 suvsuv 大大幫忙一下吧 ... |
