原帖由 千红 于 2011-1-2 23:38 发表
官方确认的PDA型号
1 Februar, 2010 - 23:52 – RV
The PDA adjustment software is designed for "XScale", "ARM" or "PXA". The primary use will be with bluetooth connection, so you need a BT module an ...
週六試了老PDA ASUS P535裝WINCE版本,千紅牌的藍牙可以連上,不錯用! |
