床身上回转直径
Swing diameter over head 360 mm
两顶尖距离
Distance between centers 300 mm
车削转速/级数
Turning speed/grade 500-1600r/min/3
纵向行程
Longitudinal stroke 210 mm
横向行程
Lateral stroke 145 mm
钻孔
Drilling 16 mm
钻铣转速/级数
Drilling and milling speed/grade 400-2000r/min/5
钻铣转行程
Stroke of milling spindle 75 mm
电动机功率
Power of motor 0.37 0.37 kw
净重/毛重
N.W./G.W. 146/210 kg
外形尺寸(长×宽×高)
Overall dimensions(L×W×H) 890×580×810 mm
