查看: 724|回复: 0
我是按照雄迈模组配IR-CUT和12mm镜头设计的
发表于 2018-3-14 08:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
适用于38mm摄像头模组的单轴俯仰舵机云台,有兴趣的可以拿去3D打印。38mm规格的摄像头模组x宝很常见,标清高清模拟数字的都有,可以自己选配。我是按照雄迈模组配IR-CUT和12mm镜头设计的。
其他配件材料还需要:
银燕9g舵机配圆盘摇臂            一个
M2 x 20 十字槽盘头螺钉         四个
M2.5 x 12 十字槽沉头螺钉      四个
502胶
因为是打印件,螺钉直接拧进去就行了,但尽量不要反复拧螺钉,否则很容易滑丝。
http://www.qipeiren.com/Supply/supply-4140399.htm
http://www.qipeiren.com/Supply/supply-4140402.htm
http://www.qipeiren.com/Supply/supply-4140401.htm
http://www.qipeiren.com/Supply/supply-4140400.htm
http://www.qipeiren.com/Supply/supply-4140403.htm
http://www.qipeiren.com/Supply/supply-4140404.htm
http://www.qipeiren.com/Supply/supply-4140407.htm
http://www.qipeiren.com/Supply/supply-4140406.htm
http://www.qipeiren.com/Supply/supply-4140408.htm
http://www.qipeiren.com/Supply/supply-4140410.htm
http://www.qipeiren.com/Supply/supply-4140405.htm
http://www.qipeiren.com/Supply/supply-4140409.htm
http://www.qipeiren.com/Supply/supply-4140413.htm
http://www.qipeiren.com/Supply/supply-4140411.htm
http://www.qipeiren.com/Supply/supply-4140414.htm
http://www.qipeiren.com/Supply/supply-4140412.htm
http://www.qipeiren.com/Supply/supply-4140416.htm
http://www.qipeiren.com/Supply/supply-4140415.htm
http://www.qipeiren.com/Supply/supply-4140419.htm
http://www.qipeiren.com/Supply/supply-4140417.htm
http://www.qipeiren.com/Supply/supply-4140420.htm
http://www.qipeiren.com/Supply/supply-4140418.htm
http://www.qipeiren.com/Supply/supply-4140422.htm
http://www.qipeiren.com/Supply/supply-4140421.htm
http://www.qipeiren.com/Supply/supply-4140423.htm
http://www.qipeiren.com/Supply/supply-4140425.htm
http://www.qipeiren.com/Supply/supply-4140427.htm
http://www.qipeiren.com/Supply/supply-4140426.htm
http://www.qipeiren.com/Supply/supply-4140424.htm
http://www.qipeiren.com/Supply/supply-4140428.htm
http://www.qipeiren.com/Supply/supply-4140429.htm
http://www.qipeiren.com/Supply/supply-4140430.htm
http://www.qipeiren.com/Supply/supply-4140431.htm
http://www.qipeiren.com/Supply/supply-4140432.htm
http://www.qipeiren.com/Supply/supply-4140433.htm
http://www.qipeiren.com/Supply/supply-4140434.htm
http://www.qipeiren.com/Supply/supply-4140435.htm
http://www.qipeiren.com/Supply/supply-4140437.htm
http://www.qipeiren.com/Supply/supply-4140436.htm
http://www.qipeiren.com/Supply/supply-4140439.htm
http://www.qipeiren.com/Supply/supply-4140438.htm
http://www.qipeiren.com/Supply/supply-4140440.htm
http://www.qipeiren.com/Supply/supply-4140441.htm
http://www.qipeiren.com/Supply/supply-4140442.htm
http://www.qipeiren.com/Supply/supply-4140443.htm
http://www.qipeiren.com/Supply/supply-4140444.htm
http://www.qipeiren.com/Supply/supply-4140445.htm
http://www.qipeiren.com/Supply/supply-4140446.htm
http://www.qipeiren.com/Supply/supply-4140447.htm
http://www.qipeiren.com/Supply/supply-4140448.htm
http://www.qipeiren.com/Supply/supply-4140450.htm
http://www.qipeiren.com/Supply/supply-4140449.htm
http://www.qipeiren.com/Supply/supply-4140451.htm
http://www.qipeiren.com/Supply/supply-4140452.htm
http://www.qipeiren.com/Supply/supply-4140453.htm
http://www.qipeiren.com/Supply/supply-4140454.htm
http://www.qipeiren.com/Supply/supply-4140455.htm
http://www.qipeiren.com/Supply/supply-4140456.htm
http://www.qipeiren.com/Supply/supply-4140457.htm
http://www.qipeiren.com/Supply/supply-4140458.htm
http://www.qipeiren.com/Supply/supply-4140459.htm
http://www.qipeiren.com/Supply/supply-4140460.htm
http://www.qipeiren.com/Supply/supply-4140461.htm
http://www.qipeiren.com/Supply/supply-4140462.htm
http://www.qipeiren.com/Supply/supply-4140463.htm
http://www.qipeiren.com/Supply/supply-4140465.htm
http://www.qipeiren.com/Supply/supply-4140464.htm
http://www.qipeiren.com/Supply/supply-4140466.htm
http://www.qipeiren.com/Supply/supply-4140467.htm
http://www.qipeiren.com/Supply/supply-4140469.htm
http://www.qipeiren.com/Supply/supply-4140468.htm
http://www.qipeiren.com/Supply/supply-4140471.htm
http://www.qipeiren.com/Supply/supply-4140470.htm
http://www.qipeiren.com/Supply/supply-4140472.htm
http://www.qipeiren.com/Supply/supply-4140473.htm
http://www.qipeiren.com/Supply/supply-4140474.htm
http://www.qipeiren.com/Supply/supply-4140475.htm
http://www.qipeiren.com/Supply/supply-4140476.htm
http://www.qipeiren.com/Supply/supply-4140477.htm
http://www.qipeiren.com/Supply/supply-4140478.htm
http://www.qipeiren.com/Supply/supply-4140479.htm
http://www.qipeiren.com/Supply/supply-4140480.htm
http://www.qipeiren.com/Supply/supply-4140481.htm
http://www.qipeiren.com/Supply/supply-4140482.htm
http://www.qipeiren.com/Supply/supply-4140483.htm
http://www.qipeiren.com/Supply/supply-4140484.htm
http://www.qipeiren.com/Supply/supply-4140485.htm
http://www.qipeiren.com/Supply/supply-4140486.htm
http://www.qipeiren.com/Supply/supply-4140489.htm
http://www.qipeiren.com/Supply/supply-4140488.htm
http://www.qipeiren.com/Supply/supply-4140487.htm
http://www.qipeiren.com/Supply/supply-4140490.htm
http://www.qipeiren.com/Supply/supply-4140491.htm
http://www.qipeiren.com/Supply/supply-4140492.htm
http://www.qipeiren.com/Supply/supply-4140494.htm
http://www.qipeiren.com/Supply/supply-4140495.htm
http://www.qipeiren.com/Supply/supply-4140496.htm
http://www.qipeiren.com/Supply/supply-4140497.htm
http://www.qipeiren.com/Supply/supply-4140493.htm
http://www.qipeiren.com/Supply/supply-4140498.htm
http://www.qipeiren.com/Supply/supply-4140499.htm
http://www.qipeiren.com/Supply/supply-4140501.htm
http://www.qipeiren.com/Supply/supply-4140500.htm
http://www.qipeiren.com/Supply/supply-4140502.htm
http://www.qipeiren.com/Supply/supply-4140503.htm
http://www.qipeiren.com/Supply/supply-4140504.htm
http://www.qipeiren.com/Supply/supply-4140506.htm
http://www.qipeiren.com/Supply/supply-4140508.htm
http://www.qipeiren.com/Supply/supply-4140507.htm
http://www.qipeiren.com/Supply/supply-4140505.htm
http://www.qipeiren.com/Supply/supply-4140509.htm
http://www.qipeiren.com/Supply/supply-4140510.htm
http://www.qipeiren.com/Supply/supply-4140511.htm
http://www.qipeiren.com/Supply/supply-4140512.htm
http://www.qipeiren.com/Supply/supply-4140513.htm
http://www.qipeiren.com/Supply/supply-4140514.htm
http://www.qipeiren.com/Supply/supply-4140516.htm
http://www.qipeiren.com/Supply/supply-4140515.htm
http://www.qipeiren.com/Supply/supply-4140517.htm
http://www.qipeiren.com/Supply/supply-4140518.htm
http://www.qipeiren.com/Supply/supply-4140520.htm
http://www.qipeiren.com/Supply/supply-4140519.htm
http://www.qipeiren.com/Supply/supply-4140521.htm
http://www.qipeiren.com/Supply/supply-4140522.htm
http://www.qipeiren.com/Supply/supply-4140523.htm
http://www.qipeiren.com/Supply/supply-4140524.htm
http://www.qipeiren.com/Supply/supply-4140525.htm
http://www.qipeiren.com/Supply/supply-4140527.htm
http://www.qipeiren.com/Supply/supply-4140526.htm
http://www.qipeiren.com/Supply/supply-4140528.htm
http://www.qipeiren.com/Supply/supply-4140529.htm
http://www.qipeiren.com/Supply/supply-4140530.htm
http://www.qipeiren.com/Supply/supply-4140531.htm
http://www.qipeiren.com/Supply/supply-4140534.htm
http://www.qipeiren.com/Supply/supply-4140532.htm
http://www.qipeiren.com/Supply/supply-4140533.htm
http://www.qipeiren.com/Supply/supply-4140535.htm
http://www.qipeiren.com/Supply/supply-4140536.htm
http://www.qipeiren.com/Supply/supply-4140537.htm
http://www.qipeiren.com/Supply/supply-4140538.htm
http://www.qipeiren.com/Supply/supply-4140539.htm
http://www.qipeiren.com/Supply/supply-4140540.htm
http://www.qipeiren.com/Supply/supply-4140541.htm
http://www.qipeiren.com/Supply/supply-4140542.htm
http://www.qipeiren.com/Supply/supply-4140544.htm
http://www.qipeiren.com/Supply/supply-4140545.htm
http://www.qipeiren.com/Supply/supply-4140543.htm
http://www.qipeiren.com/Supply/supply-4140546.htm
http://www.qipeiren.com/Supply/supply-4140547.htm
http://www.qipeiren.com/Supply/supply-4140548.htm
http://www.qipeiren.com/Supply/supply-4140550.htm
http://www.qipeiren.com/Supply/supply-4140549.htm
http://www.qipeiren.com/Supply/supply-4140551.htm
http://www.qipeiren.com/Supply/supply-4140552.htm
http://www.qipeiren.com/Supply/supply-4140553.htm
http://www.qipeiren.com/Supply/supply-4140554.htm
http://www.qipeiren.com/Supply/supply-4140555.htm
http://www.qipeiren.com/Supply/supply-4140556.htm
http://www.qipeiren.com/Supply/supply-4140557.htm
http://www.qipeiren.com/Supply/supply-4140558.htm
http://www.qipeiren.com/Supply/supply-4140559.htm
http://www.qipeiren.com/Supply/supply-4140560.htm
http://www.qipeiren.com/Supply/supply-4140561.htm
http://www.qipeiren.com/Supply/supply-4140562.htm
http://www.qipeiren.com/Supply/supply-4140563.htm
http://www.qipeiren.com/Supply/supply-4140564.htm
http://www.qipeiren.com/Supply/supply-4140565.htm
http://www.qipeiren.com/Supply/supply-4140566.htm
http://www.qipeiren.com/Supply/supply-4140567.htm
http://www.qipeiren.com/Supply/supply-4140568.htm
http://www.qipeiren.com/Supply/supply-4140569.htm
http://www.qipeiren.com/Supply/supply-4140570.htm
http://www.qipeiren.com/Supply/supply-4140571.htm
http://www.qipeiren.com/Supply/supply-4140572.htm
http://www.qipeiren.com/Supply/supply-4140573.htm
http://www.qipeiren.com/Supply/supply-4140574.htm
http://www.qipeiren.com/Supply/supply-4140576.htm
http://www.qipeiren.com/Supply/supply-4140577.htm
http://www.qipeiren.com/Supply/supply-4140575.htm
http://www.qipeiren.com/Supply/supply-4140578.htm
http://www.qipeiren.com/Supply/supply-4140579.htm
http://www.qipeiren.com/Supply/supply-4140580.htm
http://www.qipeiren.com/Supply/supply-4140585.htm
http://www.qipeiren.com/Supply/supply-4140581.htm
http://www.qipeiren.com/Supply/supply-4140582.htm
http://www.qipeiren.com/Supply/supply-4140583.htm
http://www.qipeiren.com/Supply/supply-4140584.htm
http://www.qipeiren.com/Supply/supply-4140586.htm
http://www.qipeiren.com/Supply/supply-4140587.htm
http://www.qipeiren.com/Supply/supply-4140588.htm
http://www.qipeiren.com/Supply/supply-4140589.htm
http://www.qipeiren.com/Supply/supply-4140590.htm
http://www.qipeiren.com/Supply/supply-4140591.htm
http://www.qipeiren.com/Supply/supply-4140592.htm
http://www.qipeiren.com/Supply/supply-4140593.htm
http://www.qipeiren.com/Supply/supply-4140594.htm
http://www.qipeiren.com/Supply/supply-4140595.htm
http://www.qipeiren.com/Supply/supply-4140596.htm
http://www.qipeiren.com/Supply/supply-4140597.htm
http://www.qipeiren.com/Supply/supply-4140598.htm
http://www.qipeiren.com/Supply/supply-4140599.htm
http://www.qipeiren.com/Supply/supply-4140602.htm
http://www.qipeiren.com/Supply/supply-4140601.htm
http://www.qipeiren.com/Supply/supply-4140600.htm
http://www.qipeiren.com/Supply/supply-4140603.htm
http://www.qipeiren.com/Supply/supply-4140604.htm
http://www.qipeiren.com/Supply/supply-4140609.htm
http://www.qipeiren.com/Supply/supply-4140607.htm
http://www.qipeiren.com/Supply/supply-4140606.htm
http://www.qipeiren.com/Supply/supply-4140605.htm
http://www.qipeiren.com/Supply/supply-4140610.htm
http://www.qipeiren.com/Supply/supply-4140608.htm
http://www.qipeiren.com/Supply/supply-4140612.htm
http://www.qipeiren.com/Supply/supply-4140614.htm
http://www.qipeiren.com/Supply/supply-4140611.htm
http://www.qipeiren.com/Supply/supply-4140616.htm
http://www.qipeiren.com/Supply/supply-4140613.htm
http://www.qipeiren.com/Supply/supply-4140615.htm
http://www.qipeiren.com/Supply/supply-4140617.htm
http://www.qipeiren.com/Supply/supply-4140618.htm
http://www.qipeiren.com/Supply/supply-4140619.htm
