查看: 1315|回复: 3
适用于38mm摄像头模组的单轴俯仰舵机云台
发表于 2018-3-14 08:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
适用于38mm摄像头模组的单轴俯仰舵机云台,有兴趣的可以拿去3D打印。38mm规格的摄像头模组x宝很常见,标清高清模拟数字的都有,可以自己选配。我是按照雄迈模组配IR-CUT和12mm镜头设计的。
其他配件材料还需要:
银燕9g舵机配圆盘摇臂            一个
M2 x 20 十字槽盘头螺钉         四个
M2.5 x 12 十字槽沉头螺钉      四个
502胶
因为是打印件,螺钉直接拧进去就行了,但尽量不要反复拧螺钉,否则很容易滑丝。
http://www.qipeiren.com/Supply/supply-4140548.htm
http://www.qipeiren.com/Supply/supply-4140550.htm
http://www.qipeiren.com/Supply/supply-4140549.htm
http://www.qipeiren.com/Supply/supply-4140551.htm
http://www.qipeiren.com/Supply/supply-4140552.htm
http://www.qipeiren.com/Supply/supply-4140553.htm
http://www.qipeiren.com/Supply/supply-4140554.htm
http://www.qipeiren.com/Supply/supply-4140555.htm
http://www.qipeiren.com/Supply/supply-4140556.htm
http://www.qipeiren.com/Supply/supply-4140557.htm
http://www.qipeiren.com/Supply/supply-4140558.htm
http://www.qipeiren.com/Supply/supply-4140559.htm
http://www.qipeiren.com/Supply/supply-4140560.htm
http://www.qipeiren.com/Supply/supply-4140561.htm
http://www.qipeiren.com/Supply/supply-4140562.htm
http://www.qipeiren.com/Supply/supply-4140563.htm
http://www.qipeiren.com/Supply/supply-4140564.htm
http://www.qipeiren.com/Supply/supply-4140565.htm
http://www.qipeiren.com/Supply/supply-4140566.htm
http://www.qipeiren.com/Supply/supply-4140567.htm
http://www.qipeiren.com/Supply/supply-4140568.htm
http://www.qipeiren.com/Supply/supply-4140569.htm
http://www.qipeiren.com/Supply/supply-4140570.htm
http://www.qipeiren.com/Supply/supply-4140571.htm
http://www.qipeiren.com/Supply/supply-4140572.htm
http://www.qipeiren.com/Supply/supply-4140573.htm
http://www.qipeiren.com/Supply/supply-4140574.htm
http://www.qipeiren.com/Supply/supply-4140576.htm
http://www.qipeiren.com/Supply/supply-4140577.htm
http://www.qipeiren.com/Supply/supply-4140575.htm
http://www.qipeiren.com/Supply/supply-4140578.htm
http://www.qipeiren.com/Supply/supply-4140579.htm
http://www.qipeiren.com/Supply/supply-4140580.htm
http://www.qipeiren.com/Supply/supply-4140585.htm
http://www.qipeiren.com/Supply/supply-4140581.htm
http://www.qipeiren.com/Supply/supply-4140582.htm
http://www.qipeiren.com/Supply/supply-4140583.htm
http://www.qipeiren.com/Supply/supply-4140584.htm
http://www.qipeiren.com/Supply/supply-4140586.htm
http://www.qipeiren.com/Supply/supply-4140587.htm
http://www.qipeiren.com/Supply/supply-4140588.htm
http://www.qipeiren.com/Supply/supply-4140589.htm
http://www.qipeiren.com/Supply/supply-4140590.htm
http://www.qipeiren.com/Supply/supply-4140591.htm
http://www.qipeiren.com/Supply/supply-4140592.htm
http://www.qipeiren.com/Supply/supply-4140593.htm
http://www.qipeiren.com/Supply/supply-4140594.htm
http://www.qipeiren.com/Supply/supply-4140595.htm
http://www.qipeiren.com/Supply/supply-4140596.htm
http://www.qipeiren.com/Supply/supply-4140597.htm
http://www.qipeiren.com/Supply/supply-4140598.htm
http://www.qipeiren.com/Supply/supply-4140599.htm
http://www.qipeiren.com/Supply/supply-4140602.htm
http://www.qipeiren.com/Supply/supply-4140601.htm
http://www.qipeiren.com/Supply/supply-4140600.htm
http://www.qipeiren.com/Supply/supply-4140603.htm
http://www.qipeiren.com/Supply/supply-4140604.htm
http://www.qipeiren.com/Supply/supply-4140609.htm
http://www.qipeiren.com/Supply/supply-4140607.htm
http://www.qipeiren.com/Supply/supply-4140606.htm
http://www.qipeiren.com/Supply/supply-4140605.htm
http://www.qipeiren.com/Supply/supply-4140610.htm
http://www.qipeiren.com/Supply/supply-4140608.htm
http://www.qipeiren.com/Supply/supply-4140612.htm
http://www.qipeiren.com/Supply/supply-4140614.htm
http://www.qipeiren.com/Supply/supply-4140611.htm
http://www.qipeiren.com/Supply/supply-4140616.htm
http://www.qipeiren.com/Supply/supply-4140613.htm
http://www.qipeiren.com/Supply/supply-4140615.htm
http://www.qipeiren.com/Supply/supply-4140617.htm
http://www.qipeiren.com/Supply/supply-4140618.htm
http://www.qipeiren.com/Supply/supply-4140619.htm
http://www.qipeiren.com/Supply/supply-4140620.htm
http://www.qipeiren.com/Supply/supply-4140621.htm
http://www.qipeiren.com/Supply/supply-4140622.htm
http://www.qipeiren.com/Supply/supply-4140623.htm
http://www.qipeiren.com/Supply/supply-4140624.htm
http://www.qipeiren.com/Supply/supply-4140625.htm
http://www.qipeiren.com/Supply/supply-4140626.htm
http://www.qipeiren.com/Supply/supply-4140627.htm
http://www.qipeiren.com/Supply/supply-4140628.htm
http://www.qipeiren.com/Supply/supply-4140629.htm
http://www.qipeiren.com/Supply/supply-4140630.htm
http://www.qipeiren.com/Supply/supply-4140632.htm
http://www.qipeiren.com/Supply/supply-4140631.htm
http://www.qipeiren.com/Supply/supply-4140633.htm
http://www.qipeiren.com/Supply/supply-4140634.htm
http://www.qipeiren.com/Supply/supply-4140635.htm
http://www.qipeiren.com/Supply/supply-4140636.htm
http://www.qipeiren.com/Supply/supply-4140637.htm
http://www.qipeiren.com/Supply/supply-4140638.htm
http://www.qipeiren.com/Supply/supply-4140639.htm
http://www.qipeiren.com/Supply/supply-4140641.htm
http://www.qipeiren.com/Supply/supply-4140640.htm
http://www.qipeiren.com/Supply/supply-4140642.htm
http://www.qipeiren.com/Supply/supply-4140643.htm
http://www.qipeiren.com/Supply/supply-4140644.htm
http://www.qipeiren.com/Supply/supply-4140645.htm
http://www.qipeiren.com/Supply/supply-4140647.htm
http://www.qipeiren.com/Supply/supply-4140646.htm
http://www.qipeiren.com/Supply/supply-4140648.htm
http://www.qipeiren.com/Supply/supply-4140649.htm
http://www.qipeiren.com/Supply/supply-4140650.htm
http://www.qipeiren.com/Supply/supply-4140651.htm
http://www.qipeiren.com/Supply/supply-4140652.htm
http://www.qipeiren.com/Supply/supply-4140653.htm
http://www.qipeiren.com/Supply/supply-4140655.htm
http://www.qipeiren.com/Supply/supply-4140654.htm
http://www.qipeiren.com/Supply/supply-4140656.htm
http://www.qipeiren.com/Supply/supply-4140657.htm
http://www.qipeiren.com/Supply/supply-4140659.htm
http://www.qipeiren.com/Supply/supply-4140658.htm
http://www.qipeiren.com/Supply/supply-4140660.htm
http://www.qipeiren.com/Supply/supply-4140661.htm
http://www.qipeiren.com/Supply/supply-4140662.htm
http://www.qipeiren.com/Supply/supply-4140663.htm
http://www.qipeiren.com/Supply/supply-4140664.htm
http://www.qipeiren.com/Supply/supply-4140665.htm
http://www.qipeiren.com/Supply/supply-4140666.htm
http://www.qipeiren.com/Supply/supply-4140667.htm
http://www.qipeiren.com/Supply/supply-4140668.htm
http://www.qipeiren.com/Supply/supply-4140669.htm
http://www.qipeiren.com/Supply/supply-4140670.htm
http://www.qipeiren.com/Supply/supply-4140672.htm
http://www.qipeiren.com/Supply/supply-4140671.htm
http://www.qipeiren.com/Supply/supply-4140673.htm
http://www.qipeiren.com/Supply/supply-4140674.htm
http://www.qipeiren.com/Supply/supply-4140675.htm
http://www.qipeiren.com/Supply/supply-4140676.htm
http://www.qipeiren.com/Supply/supply-4140677.htm
http://www.qipeiren.com/Supply/supply-4140678.htm
http://www.qipeiren.com/Supply/supply-4140679.htm
http://www.qipeiren.com/Supply/supply-4140680.htm
http://www.qipeiren.com/Supply/supply-4140681.htm
http://www.qipeiren.com/Supply/supply-4140682.htm
http://www.qipeiren.com/Supply/supply-4140683.htm
http://www.qipeiren.com/Supply/supply-4140684.htm
http://www.qipeiren.com/Supply/supply-4140685.htm
http://www.qipeiren.com/Supply/supply-4140686.htm
http://www.qipeiren.com/Supply/supply-4140688.htm
http://www.qipeiren.com/Supply/supply-4140687.htm
http://www.qipeiren.com/News/news-142200.htm
http://www.qipeiren.com/News/news-142202.htm
http://www.qipeiren.com/News/news-142205.htm
http://www.qipeiren.com/News/news-142203.htm
http://www.qipeiren.com/News/news-142204.htm
http://www.qipeiren.com/News/news-142201.htm
http://www.qipeiren.com/Repair/news-142200.htm
http://www.qipeiren.com/Repair/news-142202.htm
http://www.qipeiren.com/Repair/news-142205.htm
http://www.qipeiren.com/Repair/news-142203.htm
http://www.qipeiren.com/Repair/news-142204.htm
http://www.qipeiren.com/Repair/news-142201.htm
http://bbs.5imx.com/forum.php?mod=viewthread&tid=1425887
发表于 2018-4-6 17:41 | 只看该作者
新手报到,学习学习...0.0...
