查看: 3721|回复: 32
欧洲遥控器,也是FUTABA的
发表于 2007-5-3 10:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
欧洲版的大九,功能齐全
发表于 2007-5-3 10:39 | 只看该作者
好控
发表于 2007-5-3 10:45 | 只看该作者
东西不错:em26: ,图组得不好,看了有点晕,脖子有点酸:em15:
发表于 2007-5-3 11:01 | 只看该作者
脖子有点酸
发表于 2007-5-3 11:20 | 只看该作者
这个跟小9功能上有多大区别?
发表于 2007-5-3 16:32 | 只看该作者
不觉的好看哦
 楼主| 发表于 2007-5-3 17:33 | 只看该作者
原帖由 cdch 于 2007-5-3 11:20 发表
这个跟小9功能上有多大区别?
这是大9,跟小9 不在同一级别
 楼主| 发表于 2007-5-4 16:21 | 只看该作者
设备基本功能介绍如下
:em26: Excerpt from the software list:
Basic functions
Rev-counter, 1-5 blades with maximum value memory
Digital voltage display with alarm function
Receiver voltage display
Servo reverse
Fail-safe programming
3-language software: German, English, French
Switchable FM-PCM modulation
Idle trim with reverse (ATL)
Multi-Switch and Multi-Prop channel expansion modules
Data transfer between two transmitters
Two independent timers, with count-up timer, count-down timer, rhythm timer and stopwatch functions
Transmitter operating time counter
Model memory timer, for individual model memories
Model name, with up to 12 characters
10 internal model memories, can be expanded using CAMPac modules
Up to 4 model memories per module
Model memory switching (flight mode 6 - 10)
Unrestricted assignment for channels 1 - 8
Servo test (individual or all) with ATV and servo speed
Trim value memory (global, or for each flight mode separately)
Push-button trim memory in flight, for each flight mode
Unrestricted transmitter control assignment (global or for each flight mode)
Servo travel adjustment (ATV), for each flight mode separately, with exponential function, limiter and servo speed adjustment
Transmitter control travel adjustment (AFR) for each flight mode separately, with symmetrical and asymmetrical exponential function, also VTR
Travel switching (Dual Rates) 3 x, with expo function
Servo travel display on screen, includes percentage value
5 freely programmable mixers, can be cascaded, with/without trim, offset, delay, mix-unmix function
1 freely programmable 9-point mixer, can be cascaded, with/without trim, offset, delay, mix-unmix function
Trainer mode with individual function transfer and mix mode for channels 1 - 8
Reset, individual or overall
Copy program, individual or total
Code word transmitter protection
Mixer switch position warning
Hardware controls for channels 5 - 8 freely selectable
Variable servo delay, separately for each channel and for each flight mode
Digi-button, with auto-repeat function
Unrestricted mixer switch selection; multiple functions possible, individually according to flight mode
Mixer switches can be set to operate as channel switches
Unrestricted mixer trimmer selection; can also be programmed individually according to flight mode
Channels 5 - 8 can also be set to operate as mixer trimmers
8-channel switch (transmitter control as mixer switch)
Freely programmable flight mode names
Glider program GL 4 S (4 servos)
All mixers are available in 5 flight mode levels; i.e. they can be adjusted separately to suit the model抯 requirements in each flight mode
Servo centre adjustment 0 - 100% (sub-trim), optionally global or separately for each flight mode
Aileron differential and mixing to second aileron servo, optionally channel 5, 6, or 7
V-tail mixer
Trim programs 1 and 2 for ailerons, flaps and elevator, with variable delay
Aileron -> rudder
Aileron -> flap (4 end-point adjustments)
Elevator -> flap
Airbrake -> elevator, with offset
Flap -> aileron, with offset
Flap -> elevator, with offset
Flap centre adjustment
Butterfly (crow - aileron and flap), with offset
Butterfly (crow) -> elevator, with offset
Neutral trim for aileron and flap, optionally global or separately for each flight mode
Glider program GL 5 S (5 servos)
Similar program to GL 4 S, but centred on the airbrake control
Glider program GL 2 S (2 servos)
Similar functions, optimised for models with two wing-mounted servos (flaperons)
Power model program (ACRO, 2 servos)
Aileron differential and mixing to second aileron servo, optionally channel 5, 6 or 7
V-tail mixer
Aileron -> flap mixer (flaperon), adjustment of 4 end-points and offset, trim value preset
Delta mixer (aileron -> elevator)
Aileron -> rudder
Elevator -> flaperon
Rudder -> aileron
Rudder -> elevator
Flaperon -> elevator, with offset
Snap roll 1 to 4 (aileron, rudder, elevator)
Throttle pre-select 1 and 2, with delay
Variable-pitch propeller mixer, with delay
Mixer, separate elevators as ailerons 3 and 4
Helicopter
H1, H2, HR3, HN3, H4 swashplate control
9-point collective pitch -> tail rotor curve, with symmetrical or asymmetrical exponential function
9-point collective pitch curve with mixer for second collective pitch servo
Pre-selectable collective pitch trim, hover, rates and range, optionally with or without trim
9-point throttle curve
Selectable hover throttle trim, rate and range
Auto-rotation throttle setting, automatic or manual trigger, with or without trim
Trim offset for roll, pitch-axis and tail rotor functions, optionally with or without trim
Virtual swashplate rotation
Swashplate -> tail rotor
Swashplate -> throttle
Collective pitch -> tail rotor, dynamic, rate and delay
Tail rotor -> throttle
Gyro gain, position and exponential
Hover offset
Collective pitch -> pitch axis (flare compensation)
Specification:
Dimensions: 240 x 210 x 60 mm
Weight: 1580 g
Frequency band: 35.00
Channel spacing: 10 kHz
Spotfrequencies: 20.00
Transmission system: FM / PCM
more Specifications:
Functions: 10 servos
Power supply: 9.6 V NC battery
Current drain: 55 / 230 mA
(excl./incl. RF section)
Special features: Multi-module channel expansion, teacher module, rev counter sensor
发表于 2007-5-4 18:00 | 只看该作者
原帖由 dpcom 于 2007-5-3 15:01 发表
脖子有点酸
 楼主| 发表于 2007-5-7 08:44 | 只看该作者
照片没有搞好,辛苦大家了
发表于 2007-5-7 11:02 | 只看该作者
:em26: :em26:
发表于 2007-5-7 14:59 | 只看该作者
看着不错
发表于 2007-5-7 17:41 | 只看该作者
:em26: :em07:
发表于 2007-5-8 02:05 | 只看该作者
很難看哦~
 楼主| 发表于 2007-5-8 14:08 | 只看该作者
:em04: 看来人的看法有很大不同哦:em15:
发表于 2007-5-8 17:14 | 只看该作者
:em26: :em26:
发表于 2007-5-9 10:56 | 只看该作者
:em26: :em26: :em26看看。。买不起。呵呵
发表于 2007-5-11 00:33 | 只看该作者
看起来蛮结实的 像军用的
发表于 2007-5-11 03:27 | 只看该作者
:em20:
发表于 2007-5-11 06:16 | 只看该作者
这东西别看样子不咋滴,估计便宜不了。。。。。。。。。。。
