9楼
楼主 |
发表于 2004-12-23 16:05
有感无刷,速度响应一流
调速器:
Input Voltage: 6-14 cells (1.2 VDC/cell); Forward/Braking/Reverse
Case Size: 1.75” x 2.17” x 0.85”; (44.5 x 55.1 x 21.6 mm)
Weight: 4.8 oz. (135 g)
Throttle Programs: 3
Heavy-duty BEC 6 Volts/3 Amps
Watts: 375 Watts
Rated Current: 400 Amps/phase @ 25°C MOSFET Temp.
On-Resistance: 0.0013 x 2 ohms
Braking Current: 400 Amps/phase @ 25°C MOSFET Temp.
Max Discrete Steps: 256
Motor/Battery Wire: 14-Gauge Silicone
电机:
Motor Size: 2.84”; 72.1 mm (Length); 1.41”; 35.8 mm (Diameter)
Shaft Diameter: 0.125”; 3.175 mm; (accepts all existing pinion gears)
Motor Weight: 8.36 oz. (295 grams)
Heat Sink Weight: 1.97 oz. (69.5 grams)
Kv: 4,400 RPM/Volt
Kt: 0.76 in-oz/amp
Power Output: 375 watts @ 14.4 volts
Magnet: One-piece, multi-pole neodymium
Performance: Approx. 20% longer run-times |
