The Micron R/C Helicopter is currently the smallest R/C helicopter in production with a main rotor diameter of 8.25 inches.
The Micron Helicopter uses a new high density Lipo Battery pack 2 to 3 cells. These packs have very high discharge rates for there weight and size.
Specs:
Rotor: Fixed Pitch
Rotor Diameter: 8.25 inches
Length: 9 inches
Ready to fly weight: 50 grams or less
Components to be used with the Micron:
Falcon 1.7g Servos or lighter with at least 10gms of torgue
Receiver: 4 channel under 2.3 grams with micro JST connections. Recommend Falcon 2.3gm and Sky Hooks and Rigging lightwieght receivers.
ESC/Mixer: Our Mixeron Board must be used for this helicopter, because of the high performance motors used in the Micron Helicopter. This board was developed to give the highest performance and reliabilty for the Microns motors.
More info coming soon!!!
