查看: 20165|回复: 92
我搞到的无刷电调图纸望对大家有帮助
发表于 2006-4-22 22:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
实体如图:
所需元件如下:
Component        Value        Package        Description        Digikey P/N
C1        100n        805        CAP .10UF 25V CERAMIC X7R        399-1168-1-ND
C3        100n        805        CAP .10UF 25V CERAMIC X7R        399-1168-1-ND
R36        100R        805        RES 100 OHM 1/8W 1% 0805 SMD        311-100CCT-ND
R38        100R        805        RES 100 OHM 1/8W 1% 0805 SMD        311-100CCT-ND
R40        100R        805        RES 100 OHM 1/8W 1% 0805 SMD        311-100CCT-ND
R02        10k        805        RES 10.0K OHM 1/8W 1% 0805 SMD        311-10.0KCCT-ND
R04        10k        805        RES 10.0K OHM 1/8W 1% 0805 SMD        311-10.0KCCT-ND
R06        10k        805        RES 10.0K OHM 1/8W 1% 0805 SMD        311-10.0KCCT-ND
R08        10k        805        RES 10.0K OHM 1/8W 1% 0805 SMD        311-10.0KCCT-ND
R11        10k        805        RES 10.0K OHM 1/8W 1% 0805 SMD        311-10.0KCCT-ND
R18        10k        805        RES 10.0K OHM 1/8W 1% 0805 SMD        311-10.0KCCT-ND
R19        10k        805        RES 10.0K OHM 1/8W 1% 0805 SMD        311-10.0KCCT-ND
R24        10k        805        RES 10.0K OHM 1/8W 1% 0805 SMD        311-10.0KCCT-ND
R25        10k        805        RES 10.0K OHM 1/8W 1% 0805 SMD        311-10.0KCCT-ND
R29        10k        805        RES 10.0K OHM 1/8W 1% 0805 SMD        311-10.0KCCT-ND
R31        10k        805        RES 10.0K OHM 1/8W 1% 0805 SMD        311-10.0KCCT-ND
C2        10µ        SMD-B        CAP 10UF 10V TANT TE SERIES        PCS2106CT-ND
R05        20k        805        RES 20.0K OHM 1/8W 1% 0805 SMD        RHM20.0KCCT-ND
R20        20k        805        RES 20.0K OHM 1/8W 1% 0805 SMD        RHM20.0KCCT-ND
R21        20k        805        RES 20.0K OHM 1/8W 1% 0805 SMD        RHM20.0KCCT-ND
R22        20k        805        RES 20.0K OHM 1/8W 1% 0805 SMD        RHM20.0KCCT-ND
R26        20k        805        RES 20.0K OHM 1/8W 1% 0805 SMD        RHM20.0KCCT-ND
R27        20k        805        RES 20.0K OHM 1/8W 1% 0805 SMD        RHM20.0KCCT-ND
R30        20k        805        RES 20.0K OHM 1/8W 1% 0805 SMD        RHM20.0KCCT-ND
R03        2k2        805        RES 2.20K OHM 1/8W 1% 0805 SMD        311-2.20KCCT-ND
R07        2k2        805        RES 2.20K OHM 1/8W 1% 0805 SMD        311-2.20KCCT-ND
R09        2k2        805        RES 2.20K OHM 1/8W 1% 0805 SMD        311-2.20KCCT-ND
R10        2k2        805        RES 2.20K OHM 1/8W 1% 0805 SMD        311-2.20KCCT-ND
R12        2k2        805        RES 2.20K OHM 1/8W 1% 0805 SMD        311-2.20KCCT-ND
R13        2k2        805        RES 2.20K OHM 1/8W 1% 0805 SMD        311-2.20KCCT-ND
R14        2k2        805        RES 2.20K OHM 1/8W 1% 0805 SMD        311-2.20KCCT-ND
R15        2k2        805        RES 2.20K OHM 1/8W 1% 0805 SMD        311-2.20KCCT-ND
R16        2k2        805        RES 2.20K OHM 1/8W 1% 0805 SMD        311-2.20KCCT-ND
R01        47k        805        RES 47.0K OHM 1/8W 1% 0805 SMD        RHM47.0KCCT-ND
R17        47k        805        RES 47.0K OHM 1/8W 1% 0805 SMD        RHM47.0KCCT-ND
R23        47k        805        RES 47.0K OHM 1/8W 1% 0805 SMD        RHM47.0KCCT-ND
R28        47k        805        RES 47.0K OHM 1/8W 1% 0805 SMD        RHM47.0KCCT-ND
R35        47k        805        RES 47.0K OHM 1/8W 1% 0805 SMD        RHM47.0KCCT-ND
R37        47k        805        RES 47.0K OHM 1/8W 1% 0805 SMD        RHM47.0KCCT-ND
R39        47k        805        RES 47.0K OHM 1/8W 1% 0805 SMD        RHM47.0KCCT-ND
C4        47µ        extern        CAP 47UF 63V ELECT FC RADIAL        P10340-ND
R32        680R        805        RES 680 OHM 1/8W 1% 0805 SMD        RHM680CCT-ND
R33        680R        805        RES 680 OHM 1/8W 1% 0805 SMD        RHM680CCT-ND
R34        680R        805        RES 680 OHM 1/8W 1% 0805 SMD        RHM680CCT-ND
Q1        8MHz        QARTZ-SMD        RESONATOR CERAMIC 8.00MHZ SMD        X931CT-ND
IC2        AT90S2313-SO20        SO20        IC MCU 2K 10MHZ UART IT SO20        AT90S2313-10SI-ND
D1        BAS85        SOD80        DIODE SWITCH 200V 500MW MINIMELF        BAV103DICT-ND
T1        BC847C        SOT-23        TRANS NPN AF 50V SOT-23        BC847CINCT-ND
T2        BC847C        SOT-23        TRANS NPN AF 50V SOT-23        BC847CINCT-ND
T3        BC847C        SOT-23        TRANS NPN AF 50V SOT-23        BC847CINCT-ND
X4        K1X1        1X01        CONN HEADER 12POS .100 VERT TIN, BREAKAWAY        WM6412-ND
X5        K1X1        1X01
X6        K1X1        1X01
X7        K1X1        1X01
X8        K1X1        1X01
X2        K1X3        1X03
X3        K1X3        1X03
X1        K1X6        1X06
IC1        L4941 BDT        D-PAK        IC LDO 1A REGULATOR DPAK        497-1168-1-ND
D3        LGR971        805        LED GREEN S-J TYPE 0805        P11500CT-ND
D2        LHR974        805        LED RED S-J TYPE 0805        P11497CT-ND
IC3        LM339D        SO14        IC QUAD DIFF COMP 14-SOIC        296-1013-5-ND
T4        SI4420N        SO8        HEX/MOS N-CH 30V 15A 8-SOIC        IRF7455-ND
T6        SI4420N        SO8                IRF7455-ND
T8        SI4420N        SO8                IRF7455-ND
T5        SI4425P        SO8        MOSFET PCH -20V -15A 8SOIC        IRF7425-ND
T7        SI4425P        SO8                IRF7425-ND
T9        SI4425P        SO8                IRF7425-ND
所需程序如下:
http://home.versanet.de/~b-konze/blmc_bko/blmc207.asm
http://home.versanet.de/~b-konze/blmc_bko/blmc207.hex
[ 本帖最后由 飞鹰no1 于 2006-4-24 10:01 编辑 ]
 楼主| 发表于 2006-4-22 22:52 | 只看该作者
我自己也在刻苦钻研希望高手指点
发表于 2006-4-22 23:46 | 只看该作者
有没有电路图啊??
有的话量产应该没有问题!!!
 楼主| 发表于 2006-4-23 02:24 | 只看该作者
有电路图还有印刷电路板
发表于 2006-4-23 10:27 | 只看该作者
我有这个电路的PCB图,原理图和程序!
发表于 2006-4-23 15:34 | 只看该作者
对此感兴趣!
  能给我一份电路图我程序吗?
myfriendaya@yahoo.com.cn
发表于 2006-4-23 17:43 | 只看该作者
对此感兴趣!
  能给我一份PCB图,电路图和程序吗?
shsj88@21cn.com
发表于 2006-4-23 20:58 | 只看该作者
能给份我吗?
shingosu@163.com
 楼主| 发表于 2006-4-23 22:29 | 只看该作者
回复 #5 pipilu 的帖子
你有吗交流以下
发表于 2006-4-24 07:40 | 只看该作者
有啊,但我不明白你为什么在我的帖子里破口大骂!要交流可以,去把你的那些话收回去!
发表于 2006-4-24 08:32 | 只看该作者
楼上好!
  能给我一份电路图、PCB图和程序吗?
sdq-saga@163.com
发表于 2006-4-24 09:01 | 只看该作者
对此感兴趣!
  能给我一份PCB图,电路图和程序吗?
h10zg11@yeah.net
 楼主| 发表于 2006-4-24 09:53 | 只看该作者
回复 #10 pipilu 的帖子
原来是你收费的去死同意大家顶一下
发表于 2006-4-24 10:43 | 只看该作者
我收费是事先有声明,我收费是因为我付出了劳动,难道要我饿着肚子做开发?支持的请顶!
发表于 2006-4-24 15:48 | 只看该作者
强,顶
对此感兴趣,原理图和电路图能给我一份吗:engineblue@126.com
谢谢!
发表于 2006-4-24 22:37 | 只看该作者
我想要份电原理图和PCB图,能发份给我吗?谢谢!ouzhenzhong@21cn.com
发表于 2006-4-28 12:43 | 只看该作者
17楼的朋友你好!你说的也有道理,但你有见过哪个领导这个行业的人愿意只收一点点的费用就把程序拿出来给广大模友DIY吗?而我就有这个爱好!我愿意这样做却只收取一点点的回报。再说你怎么就可断定我做的只是一些低层次的东西?
发表于 2006-5-4 21:03 | 只看该作者
我现在也在研究方面的东西,不知道大侠是否也可以把SCH、PCB以及程序给我一份,万分感谢!
yjyzby@163.com
发表于 2006-5-11 00:47 | 只看该作者
对此感兴趣!
  能给我一份PCB图,电路图和程序吗?
  qhpaji2004@163.com
发表于 2006-5-12 12:32 | 只看该作者
我也想要。
可否给我电路图?wkcn@163.com
