俯仰是不会自动修正,还是不能从控上控制
如果是不能在控上控制 就这么改
新建文本文档,将下面的复制进去 保存为*.cfg格式文档,然后在软件里setting>load from file 这个不一定每个都适用,权当测试用
- %SettingsHash = (
- 'Gyro LPF' => [ 1 , '1.5 ms' ],
- 'Imu2 FeedForward LPF' => [ 1 , '1.5 ms' ],
- 'Low Voltage Limit' => [ 1 , '2.9 V/cell' ],
- 'Voltage Correction' => [ 0 , '0 %' ],
- 'Pitch P' => [ 150 , '1.50 ' ],
- 'Pitch I' => [ 1000 , '100.0 ' ],
- 'Pitch D' => [ 450 , '0.0450 ' ],
- 'Pitch Motor Vmax' => [ 150 , '150 ' ],
- 'Roll P' => [ 160 , '1.60 ' ],
- 'Roll I' => [ 1000 , '100.0 ' ],
- 'Roll D' => [ 550 , '0.0550 ' ],
- 'Roll Motor Vmax' => [ 150 , '150 ' ],
- 'Yaw P' => [ 240 , '2.40 ' ],
- 'Yaw I' => [ 1400 , '140.0 ' ],
- 'Yaw D' => [ 850 , '0.0850 ' ],
- 'Yaw Motor Vmax' => [ 150 , '150 ' ],
- 'Pan Mode Control' => [ 7 , 'Rc2-3' ],
- 'Pan Mode Default Setting' => [ 0 , 'hold hold pan' ],
- 'Pan Mode Setting #1' => [ 5 , 'off' ],
- 'Pan Mode Setting #2' => [ 5 , 'off' ],
- 'Pan Mode Setting #3' => [ 5 , 'off' ],
- 'Pitch Pan (0 = hold)' => [ 20 , '2.0 ' ],
- 'Pitch Pan Deadband' => [ 0 , '0.0 ' ],
- 'Pitch Pan Limiter' => [ 0 , '0 %' ],
- 'Roll Pan (0 = hold)' => [ 20 , '2.0 ' ],
- 'Roll Pan Deadband' => [ 0 , '0.0 ' ],
- 'Roll Pan Limiter' => [ 0 , '0 %' ],
- 'Yaw Pan (0 = hold)' => [ 15 , '1.5 ' ],
- 'Yaw Pan Deadband' => [ 50 , '5.0 ' ],
- 'Yaw Pan Limiter' => [ 0 , '0 %' ],
- 'Yaw Pan LPF' => [ 0 , '0.00 s' ],
- 'Pan Deadband Hysteresis' => [ 0 , '0.0 ' ],
- 'Rc Dead Band' => [ 10 , '10 us' ],
- 'Rc Hysteresis' => [ 5 , '5 us' ],
- 'Rc Pitch Trim' => [ 0 , '0 us' ],
- 'Rc Roll Trim' => [ 0 , '0 us' ],
- 'Rc Yaw Trim' => [ 0 , '0 us' ],
- 'Rc Pitch' => [ 4 , 'Rc2-0' ],
- 'Rc Pitch Mode' => [ 2 , 'absolute centered' ],
- 'Rc Pitch Min' => [ 65286 , '-25.0 ' ],
- 'Rc Pitch Max' => [ 250 , '25.0 ' ],
- 'Rc Pitch Speed Limit (0 = off)' => [ 400 , '40.0 ?s' ],
- 'Rc Pitch Accel Limit (0 = off)' => [ 300 , '0.300 ' ],
- 'Rc Roll' => [ 5 , 'Rc2-1' ],
- 'Rc Roll Mode' => [ 2 , 'absolute centered' ],
- 'Rc Roll Min' => [ 65286 , '-25.0 ' ],
- 'Rc Roll Max' => [ 250 , '25.0 ' ],
- 'Rc Roll Speed Limit (0 = off)' => [ 400 , '40.0 ?s' ],
- 'Rc Roll Accel Limit (0 = off)' => [ 300 , '0.300 ' ],
- 'Rc Yaw' => [ 7 , 'Rc2-3' ],
- 'Rc Yaw Mode' => [ 2 , 'absolute centered' ],
- 'Rc Yaw Min' => [ 65286 , '-25.0 ' ],
- 'Rc Yaw Max' => [ 250 , '25.0 ' ],
- 'Rc Yaw Speed Limit (0 = off)' => [ 400 , '40.0 ?s' ],
- 'Rc Yaw Accel Limit (0 = off)' => [ 300 , '0.300 ' ],
- 'Standby' => [ 0 , 'off' ],
- 'Re-center Camera' => [ 0 , 'off' ],
- 'IR Camera Control' => [ 0 , 'off' ],
- 'Camera Model' => [ 0 , 'Sony Nex' ],
- 'IR Camera Setting #1' => [ 0 , 'shutter' ],
- 'IR Camera Setting #2' => [ 2 , 'video on/off' ],
- 'Time Interval (0 = off)' => [ 0 , '0.0 s' ],
- 'Pwm Out Control' => [ 0 , 'off' ],
- 'Pwm Out Mid' => [ 1500 , '1500 us' ],
- 'Pwm Out Min' => [ 1100 , '1100 us' ],
- 'Pwm Out Max' => [ 1900 , '1900 us' ],
- 'Pwm Out Speed Limit (0 = off)' => [ 0 , '0 us/s' ],
- 'Script1 Control' => [ 0 , 'off' ],
- 'Script2 Control' => [ 0 , 'off' ],
- 'Script3 Control' => [ 0 , 'off' ],
- 'Script4 Control' => [ 0 , 'off' ],
- 'Scripts' => [ 'FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF' ],
- 'Imu2 Configuration' => [ 0 , 'off' ],
- 'Acc Compensation Method' => [ 1 , 'advanced' ],
- 'Imu AHRS' => [ 1000 , '10.00 s' ],
- 'Virtual Channel Configuration' => [ 0 , 'off' ],
- 'Pwm Out Configuration' => [ 0 , 'off' ],
- 'Rc Pitch Offset' => [ 0 , '0.0 ' ],
- 'Rc Roll Offset' => [ 15 , '1.5 ' ],
- 'Rc Yaw Offset' => [ 0 , '0.0 ' ],
- 'Beep with Motors' => [ 1 , 'basic' ],
- 'Pitch Motor Usage' => [ 0 , 'normal' ],
- 'Roll Motor Usage' => [ 0 , 'normal' ],
- 'Yaw Motor Usage' => [ 0 , 'normal' ],
- 'Imu Orientation' => [ 12 , 'no.12: -z0? y x -z' ],
- 'Imu2 Orientation' => [ 0 , 'no.0: z0? x y z' ],
- 'Pitch Motor Poles' => [ 20 , '20 ' ],
- 'Pitch Motor Direction' => [ 2 , 'auto' ],
- 'Pitch Startup Motor Pos' => [ 233 , '233 ' ],
- 'Pitch Offset' => [ 0 , '0.00 ' ],
- 'Roll Motor Poles' => [ 14 , '14 ' ],
- 'Roll Motor Direction' => [ 2 , 'auto' ],
- 'Roll Startup Motor Pos' => [ 233 , '233 ' ],
- 'Roll Offset' => [ 0 , '0.00 ' ],
- 'Yaw Motor Poles' => [ 14 , '14 ' ],
- 'Yaw Motor Direction' => [ 2 , 'auto' ],
- 'Yaw Startup Motor Pos' => [ 339 , '339 ' ],
- 'Yaw Offset' => [ 0 , '0.00 ' ],
- 'Acc LPF' => [ 2 , '4.5 ms' ],
- 'Imu DLPF' => [ 0 , '256 Hz' ],
- 'Rc Adc LPF' => [ 0 , 'off' ],
- 'Hold To Pan Transition Time' => [ 250 , '250 ms' ],
- 'Imu Acc Threshold (0 = off)' => [ 25 , '0.25 g' ],
- 'Acc Noise Level' => [ 40 , '0.040 g' ],
- 'Acc Threshold (0 = off)' => [ 50 , '0.50 g' ],
- 'Acc Vertical Weight' => [ 25 , '25 %' ],
- 'Acc Zentrifugal Correction' => [ 30 , '30 %' ],
- 'Acc Recover Time' => [ 250 , '250 ms' ],
- 'Motor Mapping' => [ 0 , 'M0=pitch , M1=roll' ],
- 'Imu Mapping' => [ 0 , '1=IC2 , 2=IC2#2' ],
- 'ADC Calibration' => [ 1550 , '1550 ' ],
- 'NT Logging' => [ 1 , 'basic' ],
- 'Mavlink Configuration' => [ 0 , 'no heartbeat' ],
- 'Mavlink System ID' => [ 71 , '71 ' ],
- 'Mavlink Component ID' => [ 67 , '67 ' ],
复制代码
