查看: 2560|回复: 17
【2008.11.13增加新图】用1/48静态模型改的超级像真ka-50共轴反浆!
发表于 2008-11-11 19:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
迷彩ka-50链接:http://www.rcgroups.com/forums/showthread.php?t=303180&highlight=ka50
黑色ka-50链接:http://www.rcgroups.com/forums/showthread.php?t=468593
改装要点:
Hi all,
Finally fitted the Revell 1:48 kit on my Lama, I will use 2s Etec 450 to save 20 grams on the lipo, so the Lama will be just 15-20 grams heavier then standard.
Will fit landingllights and a red LED too
Thanks guys....
I'm curious about flightperformance too, if it works out ok I will post more details of course!
Update:
Good: Lama with Revellbody and lighter Etec2s450
450mAh 2S Pack
http://www.allerc.com/product_info.php?products_id=1246) is only 23 grams heavier, should fly well!
Bad: One of the servo's just stopped working,will look into it this weekend
At the moment the 4-in-1 is in the tailsection and the Etec lipo in the cockpit,this small lipo fits very well. By doing so the heli balances out perfectly
It flies!
The amps were too much though for the Etec450's they became too hot, don't want to risk them....
So I flew the Kamov with an PolyQuest 2s850, heavy but it flies very well for 6-7 minutes and looks awesome in the air...
Next: Video and LEDs
Elegance 2S850 20C - $35.00
Elegance 3S850 18C - $49.00
Elegance 2S850 18C - $32.00
Compared to the 2S850-20C pack, this pack is flatter and broader.
Elegance 3S1200 20C - $55.00
Hallo Piotrrr,
I´ll be interested to see the flying video of your KA-50,
Maybe you should replace the standard landing skid by three wheels or even fly the heli without wheels or a skid.
I think the KA50 will look much better than.
I was planning to do so, but it does not look to bad to me and the skids are very nice for the less perfect landings....
Will try to arrange some video this afternoon
1、用esky lama v3 和 1/48静态拼装模型ka-50改造,重量增加50多克,用增加锂电的方式11.1v解决,原帖中是350mah电池*3=11.1v。
2、遥控接收都是原配,动力180电机没有改,冒着烧机的危险,呵呵。
3、如果要彻底解决,就的改用1818无刷电机(总重量减少30*2-15*2=30g,升力为最大600g,实际按80%算  》=480g)、增加电池50g和机身机翼等配件60g=110g,总重量增加110g--30g=70g,控制在全重190g(裸机)+70g =《 300g 左右,480g拉力 拉动300g 效果应该很好,而且时间以增加,以上还是保守的估计。
4、机身太小,安装原esky lama v3 的解决方法是机壳截成2段,如图中黑色ka-50,宽度正好,但是电池就得前后放置,调试达到重量平衡了,但是不知道电池体积是否过大放的下吗?
[ 本帖最后由 KA-50 于 2008-11-13 16:27 编辑 ]
参与人数 1威望 +2 收起 理由
论坛老模友 + 2 精品文章,感谢分享!
发表于 2008-11-11 19:39 | 只看该作者
详细介绍一下,我也试试.
 楼主| 发表于 2008-11-11 20:05 | 只看该作者
是国外模型站上找的图片
意大利的 1/48 ka-50 静态模型,我有一套,感觉都粘上零件重量不轻啊,这个貌似不改无刷和增加电池容量,是飞不爽的吧?
 楼主| 发表于 2008-11-11 20:09 | 只看该作者
BTW,意大利的 1/48 ka-50 静态模型 就是上图中黄色的那架, 是凹线凸钉的,精度度非常高,板子比较硬,重一些。
德国利华/威望的 1/48 ka-50 是凸线凸钉的,精度差一些,有些缝隙还很大,但是板子比较软,比较轻,呵呵。
发表于 2008-11-12 19:35 | 只看该作者
原来如此,谢谢了..
 楼主| 发表于 2008-11-13 14:10 | 只看该作者
[ 本帖最后由 KA-50 于 2008-11-13 17:00 编辑 ]
发表于 2008-11-13 15:09 | 只看该作者
楼上这个KA52首见!~可否给点详细的!或者链接!
发表于 2008-11-13 15:34 | 只看该作者
漂亮哦
 楼主| 发表于 2008-11-13 16:10 | 只看该作者
用google在从www.rcgroups.com上搜索的
原帖子链接:http://www.rcgroups.com/forums/showthread.php?p=10596021
 楼主| 发表于 2008-11-13 16:47 | 只看该作者
ka-52 视频
 楼主| 发表于 2008-11-13 16:48 | 只看该作者
另外一个视频下载,lama级别的ka-52,竟然还带升降起落架!:
不包括电池,重量169.5g
总重包括电池222.0g
http://www.rcgroups.com/forums/showatt.php?attachmentid=705422
http://www.rcgroups.com/forums/showatt.php?attachmentid=705274
[ 本帖最后由 KA-50 于 2008-11-13 17:11 编辑 ]
 楼主| 发表于 2008-11-13 16:57 | 只看该作者
发表于 2008-11-13 21:23 | 只看该作者
太漂亮了
发表于 2008-11-13 23:31 | 只看该作者
用拼装模型的外壳,需要把内层打磨掉一层减重,辛苦啊。
发表于 2008-11-13 23:34 | 只看该作者
发表于 2008-11-14 08:14 | 只看该作者
:em07: 狠强大的说
 楼主| 发表于 2008-11-30 15:36 | 只看该作者
~~~~~~~~~~~~~~~~~~顶~~~~~~~~~~~~~~~~~
