查看: 9393|回复: 66
民政店机械师
发表于 2010-2-5 15:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
建议大家用专用程序下 载,名称: FreeRapid 0.83(网上有)
注意:下 载的压缩文件里其中一个TXT文件里面有提示
This eBook is digitally protected from
     illegal distribution and piracy
                 eBook Code | 01056804676338399
             Unlock KEY CODE| cleRbVeloeSWLuPoE7h9EfrIuboARIuM
           IMPORTANT NOTE:
           If the password doesn't work, don't worry. Simply go to:
           http://geronimo.reklavakey.com/
           to get your FREE Unlock KEY CODE
           Do this: Search the "eBook Code" and in a second the page will
                    display the match Unlock KEY CODE of the Search Query
                    Once you receive your Unlock KEY CODE please insert it and click
                    OK to fully active and protect your eBook!
                    We strongly suggest that you cut in paste your Unlock KEY CODE
                    rather than manually type.
      READ THIS IF YOU HAVE TIME
      We collect ebooks you read on your computer, collected and organized in useful and suggestive ways.
      We have popular, most recent, classics and out-of-print gems ebooks and organized by subject.
      All eBooks in .pdf format are printable to the size up to A4.
      Or you can read them on the screen if you prefer, but some people tend to print out and mark them up
      as they are choke full of useful ideas. There are many possibilities. This, you may not do it to your
      conventional books. And not less important, you can download an entire library for free.
      All eBooks are electronic version of print publications. They are "books" converted to eBooks
      specifically to provide you works simpler, in a quick, easy to read and print.
      Intended for use with PCs (Windows or Linux) and recent Macs (OS X), our ebooks are in .pdf
      format, not audio or video. You read them on your computer screen or print them.
      We have HUGE collections of ebooks now, and we keep adding new ones and improving them all. Our ebooks
      are hand-crafted. The selection and organization is based on our judgement, not automated programs.
Why eBook?
     1) It's easy to curl up with a laptop (just a matter of habit).
     2) I actually find that I read about 50% faster this way.
     3) You also could copy hundreds of eBooks on a single Flash Disc or to your Hard Drive and
        save them.
     4) If you travel long distances or frequently, it's a lot easier to take along a single Flash Disc
        rather than boxes full of printed books. Isn't eBook wonderful?
  用电脑直译其中一段内容如下:(是另一本书的资料.)
                 电子书代码| 01056804676338399
             解锁键代码| cleRbVeloeSWLuPoE7h9EfrIuboARIuM
           重要提示:
           如果密码不工作,不要担心。只要移至:
           让你免费解锁键码
           为此:搜索“电子书守则”,并在第二个页面会
                    显示匹配解锁键代码的搜索**
                    一旦您收到您解锁键码,请插入,然后点击
                    确定以积极和充分保护你的电子书!
                    我们强烈建议您在粘贴削减您解锁键码
                    而不是手动键入。
(以上内容是另一本书的,每本书的解锁键代码是不一样的.)
有能正确使用密码完成解压的大侠,请帮忙把使用方法贴图上来.
该网站还有很多好书的,因解码问题现在暂时不发了.
The Home Shop Machinist Projects One
by Joe D.Rice
ISBN:9780941653008
Language:English
FileType:PDF
File size:75588 KB
Pages:200 Pages
Publisher: Village Press Publications Inc. - 1982-1983
项目之一是本书的第一来自民政店机械师。这是一个汇编了大多数(但不是全部)的文章发表在该杂志1982年期间和1983年,前两个出版年。这些问题很早就已经失控的流通。有很多优秀的文章这里包括已发现的这些谁民政店机械师稍后错过。
你们当中有些人知道,家店机械师是“分拆”杂志从Live蒸汽。有几十个细金属/蒸汽在现场被乞讨文件将出版加工文章。在这现场蒸汽是一种爱好杂志指示蒸汽机比例的模型及相关学科的建设,但已严重超过了仅仅少数加工物品的空间较为有限。我们开始意识到,没有针对爱好德勒斯其他杂志,以及民政店Machininst概念诞生后约6个我们的出版商的放行。虽然初期问题的条款是由“活轮船写道:”他们并不仅限于在适用于现场蒸汽爱好。他们是有用的几乎每个人都谁用机床。
这本书的内容很方便秋天到一般类别。在“技术”一节装有一项涵盖的学科范围广泛,必将给你灵感的想法真正万花筒。在“机床钻床附件”部分是不言自明,因为是“铺工具和。改进。”在他们身上,我可以肯定你会发现几个项目,将帮助您升级您的商店,您的计算机工具。最后,只是为了好玩,我们在三个“业余爱好项目”,可能挑战你的技能,并为您提供更多的机会“芯片。”毕竟,我们大多数人认为,正如他们所说,是“在它的!”
我希望这本书让你在轻松快乐的椅子上许多时间都在你的店!
乔水稻
http://rapidshare.com/files/318686068/05677576258630790.zip.html
[ 本帖最后由 WXS111 于 2010-2-6 11:28 编辑 ]
 楼主| 发表于 2010-2-5 15:30 | 只看该作者
The Home Shop machinist Projects Two
by Joe D.Rice
ISBN:9780941653015
Language:English
FileType:PDF
File size:77305 KB
Pages:240 Pages
Publisher: The Home Shop Machinist
1984 - 1985
http://rapidshare.com/files/318686452/05732156736785777.zip.html
 楼主| 发表于 2010-2-5 15:32 | 只看该作者
Home Shop Machinist Projects Three
by Joe Rice
ISBN:9780941653022
Language:English
FileType:PDF
File size:84109 KB
Pages:220 Pages
Publisher: The Home Shop Machinist, Inc.
  1986 - 1987
http://rapidshare.com/files/318687176/07384986687338346.zip.html
 楼主| 发表于 2010-2-5 15:33 | 只看该作者
Home Shop Machinist Projects Four
by Joe D.Rice
ISBN:9780941653053
Language:English
FileType:PDF
File size:92719 KB
Pages:240 Pages
Publisher: The Home Shop Machinist Inc.
1988-1989
http://rapidshare.com/files/318687570/09188914428834426.zip.html
 楼主| 发表于 2010-2-5 15:35 | 只看该作者
Home Shop Machinist Projects Five
by Joe D.Rice
ISBN:9780941653152
Language:English
FileType:PDF
File size:94454 KB
Pages:230 Pages
Publisher: The Home Shop Machinist Inc. - 1993
http://rapidshare.com/files/318688522/09888658789632207.zip.html
 楼主| 发表于 2010-2-5 15:36 | 只看该作者
Home Shop Machinist Projects Six
by Joe D.Rice
ISBN:9780941653190
Language:English
FileType:PDF
File size:94541 KB
Pages:240 Pages
1991
http://rapidshare.com/files/318689602/10683917910986576.zip.html
 楼主| 发表于 2010-2-5 15:37 | 只看该作者
Home Shop Machinist Projects Seven
by Joe D.Rice
ISBN:9780941653527
Language:English
FileType:PDF
File size:112970 KB
Pages:227 Pages
1991
http://rapidshare.com/files/318690330/10876519438316375.zip.html
 楼主| 发表于 2010-2-5 15:39 | 只看该作者
Home Shop Machinist Projects Eight by Neil Knopf
ISBN:9780941653657
Language:English
FileType:PDF
File size:116106 KB
Pages:216 Pages
Publisher: The Home Shop Machinist, Inc. - 2005
http://rapidshare.com/files/318690779/11089109950810766.zip.html
 楼主| 发表于 2010-2-5 15:43 | 只看该作者
金属加工
金属加工
Metal Working Book One by Village Press Inc
ISBN:9780941653091
Language:English
FileType:PDF
File size:107848 KB
Pages:250 Pages
Publisher: Village Press Publications - 1992
http://rapidshare.com/files/318691327/11898107743013679.zip.html
 楼主| 发表于 2010-2-5 15:45 | 只看该作者
Metal Working Book Two by Village Press Inc
ISBN:9780941653176
Language:English
FileType:PDF
File size:108236 KB
Pages:255 Pages
1990-1991
http://rapidshare.com/files/318691818/12750480872146374.zip.html
 楼主| 发表于 2010-2-5 15:46 | 只看该作者
Metal Working Book Three by Village Press Inc
ISBN:9780941653558
Language:English
FileType:PDF
File size:116647 KB
Pages:261 Pages
1992-1993
http://rapidshare.com/files/318692397/13552497224153518.zip.html
 楼主| 发表于 2010-2-5 15:47 | 只看该作者
Metal Working Book Four by Village Press Inc
ISBN:9780941653664
Language:English
FileType:PDF
File size:107204 KB
Pages:262 Pages
1994-1995
http://rapidshare.com/files/318692818/13670000945145188.zip.html
 楼主| 发表于 2010-2-5 15:49 | 只看该作者
Metal Working Book Five by Village Press Inc
ISBN:9780941653732
Language:English
FileType:PDF
File size:61471 KB
Pages:228 Pages
1996-1997
http://rapidshare.com/files/318693074/13915579567802902.zip.html
 楼主| 发表于 2010-2-5 15:57 | 只看该作者
金工车间要点
Machine Shop Essentials
by Frank Marlow
ISBN:0975996304
Language:English
FileType:PDF
File size:128510 KB
Pages:518 Pages
Publisher: Published by Metal Arts Press
2004
http://rapidshare.com/files/318693613/15399013049531304.zip.html
 楼主| 发表于 2010-2-5 15:59 | 只看该作者
金工车间商业秘密
Machine Shop Trade Secrets by James A.Harvey
ISBN:0831132272
Language:English
FileType:PDF
File size:92090 KB
Pages:313 pages
Publisher: ProShop Publishing - 2005
http://rapidshare.com/files/318694013/15960433516326285.zip.html
 楼主| 发表于 2010-2-5 16:02 | 只看该作者
伦道夫的商店
Randolph's Shop
by J.Randolph Bulgin
ISBN:9780978547509
Language:English
FileType:PDF
File size:71955 KB
Pages:227 pages
Publisher: Bulgin Forge Press Franlin, NC
2006
http://rapidshare.com/files/318694245/16142699519456608.zip.html
 楼主| 发表于 2010-2-5 16:05 | 只看该作者
机床工具
Machine Tool Pratices
by Prentice Hall
ISBN:0132702320
Language:English
FileType:PDF
File size:369034 KB
Pages:864 pages
Publisher: Prentice Hall Inc.
1998
http://netload.in/datei3HWBXh0VFv.htm
 楼主| 发表于 2010-2-5 16:11 | 只看该作者
加工基础
Machining Fundamentals
by John R.Walker
ISBN:1590702492
Language:English
FileType:PDF
File size:276516 KB
Pages:640 pages
Publisher: Goodheart-Willcox Company
2004
http://netload.in/dateiUy1en4WuG3.htm
 楼主| 发表于 2010-2-5 16:14 | 只看该作者
机械师床头阅读第一卷
The Machinist Bedside Reader vol.1
by Guy Lautard
ISBN:0969098022
Language:English
FileType:PDF
File size:84791 KB
Pages:209 pages
Publisher: Guy Lautard 1986
http://rapidshare.com/files/318695247/17120159419183209.zip.html
 楼主| 发表于 2010-2-5 16:16 | 只看该作者
机械师第二床头阅读
The Machinist's Second Bedside Reader and the Bullseye Mixture Second by Guy Lautard
ISBN:0969098030
Language:English
FileType:PDF
File size:86752 KB
Pages:207 pages
Publisher: Guy B E Lautard 1988
http://rapidshare.com/files/318695572/17211078727363815.zip.html
