查看: 4842|回复: 32
棒子国最新遥控器Aurora 9
发表于 2010-2-8 09:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Detailed Feature DescriptionsBasic Features
  • AFHSS 2.4GHz / PPM / PCM Compatible
  • Easy to Read 5.1 Inch Wide Backlit Touch Screen
  • Customizable Menus
  • One-Stop Model Type Setting
  • 3 Multi-Tasking Digital Trims
  • Fully Assignable Control Switch, Knob, Stick and Digital Trims
  • Highly Sensitive 8 Ball-Bearing Gimbals with Adjustable Tension
  • Full-Sized Comfortable Hand Grips Featuring Top Quality Elastomer
  • Selectable Control Stick Mode / Change Hardware without Opening Case
  • Power Management System (Adjustable Backlight & Auto Shut-off Time)
  • Digital Trim Nano-Adjuster (Approx. 0.025deg per step up to 5deg)
Standard Programming Features
  • 9 Assignable Control Channels
  • 3 Model Types (ACRO/GLID/HELI) Programming
  • 30 Model Memories
  • 20 Character model name
  • 8 Flight Conditions with 10 Characters
  • Throttle Lock
  • Fail-safe
  • Channel Function
  • EPA
  • Dual Rate & EXP*
  • Sub-Trim
  • Servo Reverse
  • Servo Speed (Up to 25 sec in Each Direction)
  • Servo Monitor (Monitor & Servo Test)
  • 8 Programmable Mixes (5 x 2-Point , 3 x 7-Point Curves)**
  • Trainer Port
Advanced ACRO Programming
  • 9 Wing Type (6 Main Wings, 3 Flying Wings)
  • 5 Tail Type (Main Wing: Normal, V-Tail, Ailevator) (Flying Wing: 1 Servo Rudder, 2 Servo Rudders)
  • Quick Model Options Select (Dual Engine, Retracts gear, Airbrake, Fuel mixture)
  • 7 Point Throttle Curve*
  • Throttle Cut
  • Idle Down
  • Fuel Mixture*
  • Airbrake
  • Airbrake to Elevator Mix**
  • Aileron to Rudder Mix**
  • Elevator to Camber Mix**
  • Rudder to Aileron Mix**
  • Aileron Differential*
  • Aileron to Flap Mix**
  • Camber Mix**
  • Flap Control*
  • 3 x Gyro Sensitivity (ex: AILE/ELEV/RUDD)*
  • Snap-Roll (4-Way Switching Multi Direction)**
  • V-Tail**
  • Delta Mix**
  • Ailevator**
Advanced GLIDER Programming
  • 9 wing Type (6 Main Wings, 3 Flying Wings)
  • Five Tail Type (Main Wing: Normal, V-Tail, Ailevator) (Flying Wing: 1 Servo Rudder, 2 Servo Rudders)
  • Quick Model Options Select (Motor, Retracts Gear, Airbrake)
  • Motor Control (Switch on/off)**
  • Airbrake
  • Launch (Stick Position Auto Cut Function)**
  • Camber Mix**
  • Flap Control*
  • Butterfly**
  • V-Tail**
  • Delta Mix**
  • Ailevator**
Advanced HELI Programming
  • 6 Swash Types (90° Type: 1 Servo, 3 Servos, 4 Servos; 120° Type: 3 Servos; 140° Type: 3 Servos; 180° Type: 2 Servos
  • Quick Model Options Select (Governor, Needle Control, Fuel Mixture)
  • 7 Point Pitch Curve*
  • Throttle Cut
  • Gyro Sensitivity*
  • Needle Control*
  • Swash to Throttle Mix*
  • Rudder to Throttle Mix*
  • Fuel Mixture*
  • Throttle Hold***
  • Swash Mix (Swash Rate/Calibration )***
  • Revolution Mix*
  • Governor (Three Rates)*
* Capable of  a Maximum of 24 rates by 8 flight conditions and 3 switch positions
** Capable of a Maximum of 8 Rates by 8 Flight Conditions
*** Capable of a Maximum of 3 Rates Using 3-Swicth Positions
 楼主| 发表于 2010-2-8 09:39 | 只看该作者
:em15: 显示屏很大很拉风,是我见过所有遥控器里显示屏最大最清晰的
30个模型记忆
6种十字盘,7点曲线,8种混控,9个通道
发表于 2010-2-8 10:03 | 只看该作者
慢漂亮的。。。。。。。
发表于 2010-2-8 10:17 | 只看该作者
屏不大咯
发表于 2010-2-8 10:39 | 只看该作者
去哪买啊
发表于 2010-2-8 10:45 | 只看该作者
哪里有卖的?
发表于 2010-2-8 11:03 | 只看该作者
显示屏大分辨率并不高,图形界面一个字。。。乱!
发表于 2010-2-8 11:19 | 只看该作者
好大的屏~~~~~~~~
发表于 2010-2-8 15:32 | 只看该作者
看起来棒子控还是跟不上日本控,不过至少它比国产控手了点山寨味。
[ 本帖最后由 airman72150 于 2010-2-8 15:34 编辑 ]
发表于 2010-2-8 15:48 | 只看该作者
买棒子货是智商问题
发表于 2010-2-8 16:29 | 只看该作者
很像恐龙可塞号里面的外星人
发表于 2010-2-9 00:31 | 只看该作者
准备年后下手这个控,从国外买,呵呵
发表于 2010-2-9 08:47 | 只看该作者
DSX9比他好
 楼主| 发表于 2010-2-9 09:14 | 只看该作者
确实屏幕很乱
发表于 2010-2-9 09:40 | 只看该作者
还不如买jr10x好不就多了个双通道吗
发表于 2010-2-9 09:50 | 只看该作者
所有摇杆全部CNC一下外形都做成 棒子型(玉米) 那多好又有他们国家的标志还防滑
发表于 2010-2-9 17:00 | 只看该作者
这玩意的接收机可以把飞机的状态实时发给控,可以在屏幕上显示高度速度电压之类的。不错的嘛:em19:
发表于 2010-2-9 17:15 | 只看该作者
双向信息?那单买接收肯定贵得一B
发表于 2010-2-9 19:21 | 只看该作者
按钮太小 ?? 还是触屏 ??
发表于 2010-2-10 10:14 | 只看该作者
細看時hitec的...hitec的性能還是很不錯的.就是美工差點.
看了這個控.看來hitec換了美工了.呵呵
