查看: 1440|回复: 1
[滑翔机] Megatech R/C Blimp/UFO
发表于 2003-2-19 00:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
遥控飞艇,价格在75-85美金之间:
Megatech's® Airship 1®/ Area 51® Combo Pack offers a new, exciting dimension in indoor radio control flying fun. This lighter-than-air vehicle combo comes complete with a transmitter, triple-turbofan system and both air cylinders. You can use either the 48" long Airship 1® Zero Gravity MegaBlimp air bags or the 33" diameter Area 51® MegaU.F.O. (Unbelievably Fun Object) air bags. Both air bags have special coatings with colorful designs on the anti-gravity lifting cylinder.
They can be conveniently filled with helium at any florist shop or party store. Propelled by triple-turbofan electric propulsion systems, the Airship 1®/Area 51® can be flown forward or backward with complete control over airspeed, up, down and can turn sharply in any direction including 360 degree spins.
Glowing anti-gravity indicator lights provide visual reference of the operation of the triple-turbofan unit for night flights or complex maneuvers. Controlled by a hand-held proportional transmitter with a range of over 300 feet, the Airship 1®/Area 51® delivers indoor radio controlled fun for the entire family.
Requires one 9v alkaline battery and one 3v lithium battery (available at any camera store, electronic store or pharmacy).
发表于 2004-6-20 18:45 | 只看该作者
这样的遥控飞艇谁有有?和我联系,电话0373-2371373,或发短信到013837330892
