http://www.readyheli.com/SimStick--Wireless-Adapter-for-RC-Simulators_p_37621.html
SimStick successfully tested with RealFlight v5.0
Compatibility Chart
We have successfully tested SIMSTICK with the following equipment.
Transmitters
Spektrum DX8
Spektrum DX7
Spektrum DX7 SE
Spektrum DX6i
JR DSX9
JR DSX12
Receivers
Spektrum AR6100
Spektrum AR6100e
Spektrum AR6110
Spektrum AR6200
Simulators
Phoenix Flight Sim v3
RealFlight v5.0*
*please read this page
Reflex 5.03.0 XTR
Aerofly Pro deluxe
FMS
We are currently testing with the latest version of all Simulators and Radio gear. Please keep an eye on this page for the latest info.
Does Simstick Work with Realflight?
Yes. You can operate a wireless setup with Realflight and Simstick.
Versions tested: Realflight v3.0 and RealFlight v5.0
The SimStick team recently updated their compatibility list. Click to see what was said about the compatibility with RealFlight v5.0.
However because the Transmitter/controller provided by Realflight needs to be plugged in to provide copy protection it’s not as neat as it is with the “simleads” provided with Phoenix Flight Sim. We have tested with the older and newer controllers provided by RealFlight.
NOTE: You must have the Futaba Square Pin to Jack lead they supply in the Software box…. see below.
To setup you require:
1) A Simstick!
2) JR to Futaba square pin to connect to their own controller (JR 3.5mm Jack to Futaba Square 6pin). This is provided by with your RealFlight Software. It can be obtained from RealFlight if you do not have yours
[ 本帖最后由 XBOY 于 2010-12-3 21:16 编辑 ] |
