查看: 1973|回复: 4
MS Hornet and Schweizer 300
发表于 2003-1-10 17:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
[这个贴子最后由vidct在 2003/01/30 07:45pm 编辑]
最近我在研究这个产品:
http://www.mscomposit.com/Products/Hornet/hornet.html
Main rotor diameter (mm)
490
Overall length (without blades)
600
Model height (mm)
160
Weight (starting) g
240-280
Transmission rate
1:18:4
Tail rotor drive
carbon wire
Rotorhead
fixed pitch
Engine
Speed 300
Main rotor speed
up to 1500 rpm
Regulator
MS-Regulator, 5A, weight 9 g
Gyro
MS Modified CSM 180
Batteries
7xNiMH, 880mAH, 8.4V
Receiver
MS-Receiver 4-channel
Transmitter requirements
4-channel
Flight time
8-12 min
Packaging
Base HORNET Kit MS-100:
HORNET kit, not assembled, incl. main rotor blades
Speed 300 engine
Assembly instructions
Recommended accessories
MS-Receiver at least 4 channel
MS-Regulator, 5A, 9g
MS Modified CSM 180 piezo gyro
MS NiMH Battery pack for HORNET
MS NiMH Battery charger
3x microservo
Full HORNET Kit MS -1xx (xx for frequency range)
Speed 300 engine
MS-Receiver 5 channel* - 35, 40 or 72 MHz range
MS-Speed Controller BEC, 5A, 9g
MS NiMH Battery pack for HORNET, 700 MAh
3x microservo
* The receiver is modified - the 5 channel is tuned as 6th one for CCPM control!
Schweizer 300 Packaging:
MS-300 MS Schweizer 300 basic kit, analogue to Hornet basic kit
MS-301 MS Schweizer 300 upgrade - if you have  Hornet already,   this is the choice
MS-335 MS Schweizer 300 Full kit - all electronic included, for 35MHz range
MS-340 MS Schweizer 300 Full kit - all electronics included, for 40 MHz range
MS-372A MS Schweizer 300 Full kit - all electronics included, for 72 MHz range - Futaba
MS-372B MS Schweizer 300 Full kit - all electronics included, for 72 MHz range - JR
For details look at Hornet packaging - the concept is the same!
尾桨轴传动!
发表于 2003-1-31 03:55 | 只看该作者
休斯300南京亿达模型有卖的。
 楼主| 发表于 2003-1-31 04:04 | 只看该作者
这不是普通的休斯,你讲的可能是油动机,对吗?
而这个是微型电动直升机,和飞达差不多大。还有它有个最大的特点,它的尾桨是用轴传动的。
发表于 2003-2-2 06:43 | 只看该作者
研究得如何?为轴传动的优点明显吗?性能比piccolo好的话我也考虑试试。
不过它不是ccpm的,想作特技需要花不少银子升级。
 楼主| 发表于 2003-2-2 06:58 | 只看该作者
是CCPM的
