查看: 1494|回复: 0
I discover something....on my SKY-LARK
发表于 2003-4-3 06:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
I have tried many batteies...
1. Feda 8.4V 600MAH NiMH
2. my own Sanyp 8.4V 250mah NiCD
3. other is Tamiya 8.4V 1200Mah NiCD
I just want to test the raising power... (ignore the weight)
I find that it can take off....!!!!
so I guess that is my Main Motor problems!!!! no the battery problems!!!
but I just open my motor (from Sky-Lark ), I see that the brushes are ok.. :em14:
