查看: 1385|回复: 3
肥狗的狗粮 7S 65C的 大罐头
发表于 2011-5-18 11:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
以前14s飞固定翼都是6S+6S+2S的配置
现在Voltz出了新的7SLipo,肥狗的标准狗粮啊,看看足以,养不起啊,不过售价比TP 6S 65C的要便宜一些
VT510065C7S Voltz 5100mAh 7S 25.9V 65C Lipo Pack
Pack Usage:  Mikado Logo XXTREME as part of a flight pack pair.
Voltz Lithium Polymer batteries are low-cost, high performance packs that deliver their full capacity & meet their discharge ratings. These batteries are intended to deliver the maximum amount of fun with the least amount of sticker-shock possible!
All Voltz batteries come with Deans Ultra T-type connectors pre-soldered!
Specs:
- Voltage: 25.9V
- Capacity: 5100mAh
- Discharge Rating: 65C
- Burst Discharge Rating: 130C
- Charge Rate: 1-3C Recommended, 4C Max
- Size: 156mm(L) 49mm(W) 63mm(H)
- Weight: 1001g 重量还不错,没多出来多少,猜测大肥狗起飞重量应该在6000g以下
- Max Continuous Discharge: 65C (331.5A)
- Max Burst Discharge: 130C (663A)
- Balance Plug: JST-XH
发表于 2011-5-18 11:44 | 只看该作者
:em26:
发表于 2011-5-18 12:30 | 只看该作者
14S,接电池的时候会触电不?:em15:
发表于 2011-5-18 14:57 | 只看该作者
36V电压就有触电感觉了吧
