查看: 2009|回复: 6
大小电直之一网打尽篇
发表于 2003-1-31 04:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Piccolo Electric Micro Helicopter
Main rotor diameter: 500mm
Batteries: Lithium / NiMH 7 or 8 Cell
Weight: 240-280g
Tail rotor drive: Motor controlled
Rotorhead: Fixed Pitch / Collective Pitch
Flight Time: 7m - 20m
Hornet Electric Micro Helicopter
Main rotor diameter: 490mm
Weight: 240-270g
Tail rotor drive: CF Drive Shaft
Flight Time: 7m - 14m
IKARUS Eco-8 / Eco-16
Main rotor diameter: 1060mm
Overall length (without blades): 910mm
Weight: 1270g
Tail rotor drive: Belt
Rotorhead: Collective Pitch
Batteries: 6 - 12 Cells
Joker
Main rotor diameter: 1550mm
Weight: 5200g
Tail rotor diameter: 290mm
Batteries: 30 - 32 Cells
Flight time: 7m - 10m
Logo 10 / 20
Main rotor diameter: 1150mm
Weight: 2600g
Tail rotor diameter: 240mm
Batteries: 10 - 14 Cells
Flight time: 8m - 12m
Dragan Fly
俺管这叫龙飞凤舞机
Overall length from rotor to tip: 28”
Weight: 481g
Motors: 4 motors / direct prop drive
Flight Time: 5 - 6 minutes
Control: full Helicopter stick control
还有Video下:
http://www.helihobby.com/download_files/draganFlyVideo1.wmv
Hover Fly
很奇特的机机
Rotor Diameter: 350mm
Motors: 3 Motors with electronic mixing
Flight time: Unlimited
Power source: Power supply 34V DC
Weight: 68g
……未完待续
 楼主| 发表于 2003-1-31 04:34 | 只看该作者
大小电直之一网打尽篇
Why Fly Electric ?
为什么要飞电动?
> No starter Problems
没有启动的困扰
> No messy Oils
没有肮脏的燃料
> No Fuel Bills
没有燃料的帐单
> Very Quiet
非常安静
> No Engine Cuts
没有引擎的消耗
> No Carb Skills
不需要太多的技巧
> Longer flight time
较长的飞行时间
ps.翻译不妥之处望大力匠正
发表于 2012-9-9 21:03 | 只看该作者
拿分 升级 走人
发表于 2012-9-9 21:19 | 只看该作者
快10年的老坟都给挖出来了!
快10年的老坟都给挖出来了!
发表于 2012-9-9 21:48 | 只看该作者
我靠 5imx刚开站时候的帖子啊!好久没见vidct元帅了
