呵呵,开始是不太明白,这几天消化了一下, 终于开始入门了,收集了些东西,大家看看
Bell D Bell H Stat D L x H Shaft
LP Make Model Speed Made in [mm] [mm] Poles [mm] [mm] [mm] BB Comments
1 Acer 620A 002 20x Taiwan 22.0 7 9 18.0 4.5 x 6.0 2 No BL CAN type (ventilated). Needs 4mm OD BB
2 BTC BCE 833IE ??? Taiwan 23.5 7 9 20.0 4.5 x 4.5 3 No
3 Afrey CD-2056E 56x China 24.0 9 9 19.5 5.0 x 7.0 3 Yes Very nice, but black magnet and weak bell
4 Teac CD-532E ??? Malaysia 25.0 8 9 22.0 5.5 x 4.0 3 No NO USE - Plastic ring connected to bell holds the shaft
5 Teac CD-55A 4x Japan 24.0 5 9 20.0 5.0 x 4.0 2 Yes GOOD 15g motor
6 Aztech CDA-268-01A 2x Singapore ------- -------- ----- ----- ------- ------- ------ NO USE - Brushed motor
7 Philips CDD4401/71 4x4x32 Hungary 24.0 8 6 19.5 9.0 x 5.5 3 No 6-pole nice
8 Nec CDR-273 ??? Japan 22.5 6 9 19.5 4.5 x 3.5 3 No Brushless CAN type (very small)
9 Nec CDR-3000A ??? Japan 24.0 6 9 20.0 5.0 x 4.0 3 No
10 Sanyo CDR-H94A ??? Japan ------- -------- ----- ----- ------- ------- ------ NO USE - Brushed motor
11 Wearnes CDS-2420 24x2x2 Malaysia 28.0 5 9 24.5 7.0 x 4.5 3 No Bell-shaft very weak connection
12 Sony CDU4811 48x Japan 27.5 8 9 24.5 6.5 x 4.0 3 No Big, heavy
13 Matsushita CR-562-B ??? Japan ------- -------- ----- ----- ------- ------- ------ NO USE - Brushed motor
14 Matsushita CR-585-B 24x Japan 23.0 9 9 19.0 4.0 x 4.5 2 No NO USE - Plastic ring connected to bell holds the shaft
15 Sanyo CRD-254P(GR) 2x Japan 22.0 10 9 18.0 6.5 x 5.0 2 No BL CAN type (ventilated). Needs 4mm OD BB
16 Mitsumi CRMC-FX001D 2x Japan 24.0 3 6 ----- ------ 2 Yes Used for Ball Bearing only. Coreless, not able to rewind.
17 Mitsumi CRMC-FX120T 12x China 24.0 6 9 20.0 5.0 x 5.0 3 Yes Small light
18 Mitsumi CRMC-FX240S 24x Philipines 24.0 7 9 20.0 5.0 x 5.0 3 No
19 Mitsumi CRMC-FX320S 32x Japan 24.0 6 9 20.0 5.0 x 4.5 3 No Heavy brass ring connected to bell holds the shaft -needs to be grinded
20 Mitsumi CRMC-FX4010M 40 x Japan 24.0 6 9 20.5 5.0 x 4.5 3 No Light brass ring connected to bell holds the shaft
21 Mitsumi CRMC-FX4820T 48x China 24.0 7 9 20.5 5.5 x 4.5 3 No
22 Pionier DR-444 12x Japan 26.0 5 9 22.0 6.0 x 2.5 3 No NO USE - Heavy ring connected to bell holds the shaft
23 GoldStar GCD-R580R 8x Korea 22.0 10 9 18.0 5.0 x 7.0 3 No Brushless CAN type
24 HP HP C4392-5600 4x24 Malaysia 24.0 6 9 20.0 5.0 x 4.0 3 Yes Small light
25 Lite-on LTN-301 ??? Taiwan 23.5 7 9 20.0 4.5 x 5.0 3 No
26 Toshiba XM-2002B 16x Japan 29.0 8 9 23.5 5.0 x 5.0 3 Yes Big, heavy
27 Toshiba XM-5301B ??? Japan ------- -------- ----- ----- ------- ------- ------ NO USE - Brushed motor
28 Toshiba XM-5702B ??? Japan 29.0 8 9 24.0 6.0 x 4.5 3 Yes Big, light |
