查看: 2803|回复: 19
定速,这是真的吗???
发表于 2012-1-7 16:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Not all ESCs are phase detector friendly and the magnets are really easy to make up and fit.
The expensive ESC’s with built in governors don’t work very well because they have noise filtering that delay the signal from the receiver.
The inexpensive Chinese ESC’s work best with an external governor.
Align ESC’s might be ok but they are not very reliable
People write that VBar + HobbiWing running beter than ESC's like Kontronik or CC ,I thought maybe with CGY750 the same situation probably will be new firmware, then something has changed
详见http://www.helifreak.com/showthread.php?t=295456&page=7
Here is the result of my testing of which ESC's have the best chance to work with the VBar governor.
I would suggest keeping in mind that these are cheaper ESC's, overhead on ratings is not something that is likely to be abundance of, so going for a bigger one instead of smaller is what I did.
TESTED AND CONFIRMED
HobbyWing Platinum Series
(also sold as Turnigy K-Force)
Do not mix up with older version which is called Pentium, Sentilon etc which has serious reliability issues.
External programmer required: No (all done with sticks)
Settings for optimal performance: Factory settings + Startup type: Very soft
Notes:
When using Phase sensor AND separate RX pack, common ground must be shared, run a cable with Negative lead only from RX -> Programming interface on ESC.
Overall: Very good performance, good soft start with above settings
Fusion Hawk 100 and 120A BL
(also sold as Mega Power Future 100/120A, SJ Propo 100, and 120A BL)
External programmer required: Yes (purchased separately)
Setting for optimal performance: Fastest throttle response setting, Set motor start power to lowest (default).
Turn Brake OFF!
Overall: Very good performance, built in Fan, a bit large form factor.
Align ESCs
(Included in various heli combos)
Setting for optimal performance: Fastest response possible.
Notes:It has been reported some inconstancies with Phase sensors and Align motors, do not know if that’s motors fault, phase sensor or esc.
Then you might need to switch to magnet type of sensor.
Overall: Good performance.
CURRENTLY NOT OPTIMAL
Castle Creation
 楼主| 发表于 2012-1-7 16:43 | 只看该作者
NOT WORKING (or with bad performance)
Kontronik all versions (Jive, Jazz, Koby) Kontronik is aware.
Scorpion – Talking with Scorpion about this.
Turnigy Super Brain (max 6s but with BEC and logging) – Has no airplane mode, always in heli governor, not usable.
 楼主| 发表于 2012-1-7 16:44 | 只看该作者
发表于 2012-1-7 17:50 | 只看该作者
没错,是真的
发表于 2012-1-7 17:58 | 只看该作者
阴阳文   看不懂
发表于 2012-1-7 18:11 | 只看该作者
:em22:
 楼主| 发表于 2012-1-7 19:27 | 只看该作者
总起来说,好盈是Kontronik JIVE平民替身:em19:
VBar + HobbiWing设置调整好的话,运行性能要好于JIVE和凤凰之类的ESC
原话:VBar + HobbiWing running beter than ESC's like Kontronik or CC
[ 本帖最后由 keli898 于 2012-1-7 19:29 编辑 ]
发表于 2012-1-7 21:23 | 只看该作者
看到过这个帖子
帖子作者测试下来,和vbar governor搭配最好的是hobbywing的电调, 至于有没有好过jive,没有记录图片也不能听作者的片面之词
发表于 2012-1-7 21:28 | 只看该作者
:em26:
发表于 2012-1-7 22:34 | 只看该作者
VBar的定速是不是要装磁铁、感应头的?
发表于 2012-1-8 12:40 | 只看该作者
vbar5.2的电子定速是接了一个测量电机相位的小模块,这样对于电机转速的反馈更加准确,理论上是很好的。改天弄个试试效果。:em15:
发表于 2012-1-8 15:46 | 只看该作者
定不定的了是一回事,能不能稳定工作不起火是另外回事
发表于 2012-1-8 21:08 | 只看该作者
没错,是真的
发表于 2012-1-9 18:44 | 只看该作者
:em20: 哥  教我英语的老师是个美女  你懂的!
发表于 2012-2-8 21:50 | 只看该作者
顶LS,俺也是啊……
发表于 2012-3-24 16:20 | 只看该作者
顶LS的LS,俺也是啊……
发表于 2012-3-24 16:54 | 只看该作者
下次百度翻译下再发啊,麻烦你一下,方便好多人。
发表于 2012-3-24 18:18 | 只看该作者
看得我天一半,地一半,E文很差,非常有压力
发表于 2012-3-25 19:45 | 只看该作者
WOKANBUDONG,SHUILAIGEIFANYIYIXIA:em15:
发表于 2013-1-19 11:43 | 只看该作者
