查看: 1664|回复: 0
apm官网上关于如何设置V尾的说明
发表于 2014-7-7 12:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
http://plane.ardupilot.com/wiki/ ... ng_up_a_VTAIL_plane
给用“APM+死胖子”的模友。
在MANUAL模式下,不需要设置遥控器的混控,APM会帮你完成这个功能,原文如下:
MANUAL
Regular RC control, no stabilization. All RC inputs are passed through to the outputs. The only ways in which the RC output may be different from inputs are as follows:
    if the VTAIL_OUTPUT option is enabled, then a software VTAIL mixer is applied on the output
链接在这:
http://plane.ardupilot.com/wiki/flying/flight-modes/#MANUAL
