查看: 1068|回复: 1
英文版的LOGO电直配置,要慢慢看.
发表于 2006-1-5 17:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Heli:
Mikado LOGO 20
Pilot name (first/last):
Glen Peden
Motor:
Pletti 300/25/A3H
ESC:
Schulze Future 35 Ho
#/type of cells:
24 x RC2400
Pinion:
8T
Blades:
MS 600 3-D
Ready to fly weight:
3793 gm
Servos:
JR9011
Gyro/Servo:
Futaba GY401/S9253
Aerobatic RPM:
1620
Turbo RPM:
1800
Flight time-mild aerobatic
6 minutes
Flight time-heavy aerobatic
5 -1/2 minutes
Upgrades:
100/70 head, carbon fins, gyro mount, carbon elevator lever, BB tail rotor arm, alu mixing hub,
Comments:
Nice cyclic performance and power boost from upgrade head with its longer flybar and 28 mm longer rotor span
email:
glen@logoheli.com
URL:
logoheli.com
Heli:
Mikado LOGO 10
Glen Peden
Motor:
Kontronik FUN 600-18
ESC:
Schulze Future 45 Ho
#/type of cells:
13 x RC2400
Pinion:
14T
Blades:
Mikado 500 mm F/G
2490 gm
Servos:
JR DS3421
Gyro/Servo:
Futaba GY401/S9253
Aerobatic RPM:
Turbo RPM:
5-1/2 minutes
5 minutes
Upgrades:
Alu/thrust bearing/spindle, hardened steel main shaft, BBmixing hub, BB mixing arms, 3-D dampers, 3-D paddles, carbon fins, BB T/R lever, hardened steel T/R shaft, Alu swash, UBEC, tail boom brace, clamping ring
Comments:
Losing a bit of weight and installing 3-D paddles made a noticeable change in performance
Heli:
MIkado Logo 20 (11/2000 production)
Risto Koiva
Motor:
Plettenberg HP 300/25/A3 Heli
ESC:
Schulze future-35Ho
#/type of cells:
20 Sanyo 2400RC inline soldered
Pinion:
9T
Blades:
Flight and Guide Anti-Gravity 600mm symmetrical
3630g
Servos:
3x Futaba S9001
Gyro/Servo:
Futaba GY401 + Futaba S9253
Aerobatic RPM:
1600
Turbo RPM:
5min 30 sec
4min 30 sec
Upgrades:
carbon gyro mounting plate, carbon elevator lever kit, carbon horizontal tail fin, carbon vertical tail fin, aluminum washout, updated rotor-head double balls, ball bearing tail rotor lever, Logo30 landing bow, K&S SP-30 Pink Paddles, Robbe tail-boom mounted servo holder, carbon tail pitch control rod
Comments:
Nice powerful setup for everyday 3D and wireless camera works.
email:
risto.koivaNOSPAM@web.de
URL:
http://www.mh.ttu.ee/risto/rc/
Heli:
Mikado Logo 10, European Kit
Risto Koiva
Motor:
ESC:
Schulze future-18.46K
#/type of cells:
12 Sanyo 2400RC
Pinion:
15T
Blades:
Mikado 500mm CFK symmetrical
2650g
Servos:
3x Graupner/JR DS361
Gyro/Servo:
Aerobatic RPM:
1650
Turbo RPM:
mild aerobatic: 5 min 30 sec
heavy aerobatic 5 min
Upgrades:
carbon gyro mounting plate, carbon tail boom, extra tail holder, carbon horizontal tail fin, carbon vertical tail fin, aluminum swash-plate, ball bearing tail rotor lever, Logo20 flybar rod, K&S SP-3D Pink Paddles, hardened main steel shaft, hardened tail rotor shaft thrust bearing set, auto-rotation hub, motor heat-sink, Robbe tail-boom mounted servo holder, carbon tail pitch control rod, ball beared mixing arms.
Comments:
Flies unbelievably stable with standard flybar and paddles
email:
URL:
Heli:
MIkado Logo 10
Stephen Chen
Motor:
Hacker B50-13L Heli
ESC:
Schulze 45Ho
#/type of cells:
14 HRSC2600 and 14 CP2400
Pinion:
Blades:
MS Carbon 520mm
3lbs 11oz w/o batteries
Servos:
JR DS361
Gyro/Servo:
Futaba GY401/9253
Aerobatic RPM:
around 1800
Turbo RPM:
5.5min with CP2400, 6-7min with HSRC2600
.5 min-1 min less
Upgrades:
Aluminum swashplate, KSJ paddle, logo20 flybar, 3D dampner, thrust bearing, auto hub, carbon vertical fin.
Comments:
This is my Mellow Yellow #1
email:
stephenchen168NOSPAM@yahoo.com
URL:
Heli:
Logo 20
Hung Trinh
Motor:
Tango 45-8
ESC:
Beat 50-8-30
#/type of cells:
24 Sanyo 2400RC inline soldered
Pinion:
9T
Blades:
(homemade Carbon fiber) 600mm symmetrical
Around 8lbs
Servos:
3x Futaba S9202
Gyro/Servo:
Aerobatic RPM:
1680
Turbo RPM:
6min
5min
Upgrades:
Carbon elevator lever kit, carbon horizontal tail fin, carbon vertical tail fin, aluminum washout, updated rotor-head double balls, X-cell Paddles.
Comments:
Nice and powerful setup for everyday 3D
email:
hunter_trinhNOSPAM@yahoo.com
URL:
Heli:
MIkado LOGO 20
Rob Campbell
Motor:
Tango 45-08
ESC:
Kontronik Beat 50-8-30
#/type of cells:
24 x CP2400
Pinion:
9T
Blades:
SAB Composit 600mm
Servos:
s9202
Gyro/Servo:
Futaba GY401/S9253
Aerobatic RPM:
1700
Turbo RPM:
6+
Upgrades:
carbon vertical fin, gyro mount, elevator lever
Comments:
email:
URL:
Heli:
Mikado LOGO 10
Gary Wright
Motor:
Hacker C50 13L
ESC:
Schulze speed control
#/type of cells:
4 series, 4 parallel thunder power battery pack (lith polymer)
Pinion:
13T
Blades:
Mikado 500mm F/G
Servos:
futaba 3102
Gyro/Servo:
Futaba GY401/S9253
Aerobatic RPM:
Turbo RPM:
18 - 20 minutes of constant 3-D
Upgrades:
K&S paddles, aluminum swash, auto unit, graphite fins, rear graphite gyro mount
Comments:
email:
gary@gwmp.net
URL:
Heli:
Mikado LOGO 10
John Garst
Motor:
Hacker 50 15L
ESC:
Schultze Future 18.46
#/type of cells:
14xGP3300
Pinion:
16Tooth
Blades:
Mah 500(86 gram)
Servos:
HS 85MG
Gyro/Servo:
Futaba GY401/S9253
Aerobatic RPM:
1900
Turbo RPM:
9 minutes
7.5 minutes
Upgrades:
boom gyro mount, Hacker heat sink on 50 15L,360 flybar/KSJ paddles, control bridge modification (prototype-with steel balls and cupped washers) to be produced by Mikado)), tail boom brace.
Comments:
This set-up is not as hot as some others that I have tried, but exhibits a good balance between flight times and flight power for heavy aerobatics/3D. The ESC is using timing mode3 and expert speed regulation in governor mode. The transmitter throttle curves are in Normal: 0,0,50,70,90 in Idle-up(1&2): 90,90,90,90,90.There is no tendency to run hot with this set-up.
email:
BIGRCR@netzero.net
URL:
Heli:
Mikado LOGO 10
John Garst
Motor:
Aveox 36/30/1.5
ESC:
#/type of cells:
14xGP3300
Pinion:
13tooth/14tooth
Blades:
Mah 500 (86 gram)
Servos:
HS 85MG
Gyro/Servo:
Futaba GY401/S9253
Aerobatic RPM:
13=1900/14T=2020
Turbo RPM:
13T = 6.5 minutes; 14T = 5.5 minutes
13T = 6minutes; 14T = 4.5 minutes
Heli:
MIkado Logo 10
Gary Goodrum
Motor:
Aveox 36/30/2
ESC:
Aveox SL-48
#/type of cells:
5s4p Thunder Power LiPos
Pinion:
14T
Blades:
Stock 500 mm Woodies
6.06 lbs / 97 oz / 2716 gms
Servos:
JR DS368 x 3
Gyro/Servo:
Futaba GY401/9253
Aerobatic RPM:
1920
Turbo RPM:
20-25 minutes
Heli:
Mikado LOGO 10
Reidar Otto Johnsen
Motor:
Kontronic Fun 600-18
ESC:
Kontronic Smile 50-6-18
#/type of cells:
12xSanyoNIMH3000
Pinion:
14 T
Blades:
Mikado 500 mm F/G
Servos:
JR/Graupner 361
Gyro/Servo:
Futaba GY401/S9253
Aerobatic RPM:
Turbo RPM:
5 -1/2 minutes
Upgrades:
carbon gyro mounting plate, carbon vertical tail fin, ball bearing tail rotor lever, auto-rotation hub
Comments:
Nice and calm for a beginner like me.
email:
rojohnse at broadpark dot no
URL:
http://home.no.net/heliro2r/hjem2.html
发表于 2006-1-5 18:37 | 只看该作者
NO PICTURES!!?
